Question about Samsung Televison & Video
When powering Samsung TFT-LCD it turns on w/dots or lines in the screen that are only removed if restarted (usually multiple restarts are necessary). Also, on occassion, the TV will do a series of beeps while powering on; sometimes taking up to 5 minutes to get a picture on the screen. Then the picture is not good requiring a restart anyway!
  • 734 Answers
I f the TV needs warm up to get working right; don't turn off for a few days and see if moisture on the circuits can be dried off. Or keep it on standby to prevent build up of any condensation on the circuits.
Posted on Mar 11, 2011
I have a gateway flat screen FPD2275W TFT LCD Monitor and when I eitehr reboot or turn the system off, on restarting find a flat screen. I noticed that when I restarted from that state it would cont
The most common cause of that type problem is a failure of the filter capacitors on the power supply board. There are 7 capacitors that filter the output voltages from the board and when they start to die the power supply board can not start correctly. When you let the unit sit for a while they can finally build up a charge and allow the board to power up the monitor. The worst they get the longer the time will take to get a picture until one day - No picture at all. The board is easy to repair, you will get need to remove and replace the bad capacitors on the board. Here is a link to information showing where the capacitors are located on the board and the values needed to replace them.
www.ccl-la.com/catalog/product_info.php?products_id=100
I hope this helps,
BuddyMc
Nov 26, 2012 | Computers & Internet
Three-year old 47" Samsung LCD. At first, some pixelation, usually correctable by turning TV off then on again. This situation lasted months, getting slightly more frequent each week. More recently, the TV...
1. the motherboard might be bad and you will need to replace it. 2. or The power supply is bad
Chances are if its making clicks the power supply is bad and you will need to replace it. Which makes sense because constantly powering the tv on and off will damage the power supply or possibly short out your motherboard. These things usually cost about 200 bucks to fix at a local tv repair store.
Sep 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
There is horizontal line come in TFT in last 2 yr i ask the dealer he told that its bcoz some resister short now after another line come in my TFT whats the problem? and notice that this problem come after...
You may have failing TFT (Thin Film Transistor, each pixel on the screen is driven by one transistor, so there are 100 of thousands on the LCD panel
) or bad connection or failing T-CON board.
See pictures here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
It will usually get worst with more lines as time goes by. New panel will be needed.
Jun 15, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung LCD Flatscreen only shows lines of color or purple dots
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 18, 2017 | Philips 42HF7444T 42 in. Plasma TV
Samsung LCD TV slow to start
Dont have a solution, my samsung 46 inch is doing same thing. Have you found a solution?
Oct 05, 2009 | Samsung LNT5265F 52 in. LCD HDTV
My gateway fpd1975w tft lcd monitor does not work. the power button just flashes blue and nothing comes on. i put an old monitor to my computer and it worked fine, and i hooked my monitor up to an old...
Restart the PC and get into SAFE MODE. Hit and release F8 many times right after turning on PC. If it works, then go into your video setting and either change the settings or remove the video driver. Restart the PC and you'll get 800X600 screen, then reinstall the video drivers. IF it won't go above 800X600, screen internals are bad, LCD toasted. I've seen that happen with LCDs and older monitors.
Jul 05, 2009 | Gateway FPD1975W 19" LCD Monitor
Powers up, shows test menu then black screen
This sounds like a video problem with the COMPUTER.....try the monitor on another computer. Usually, if you can see the monitor test pattern the monitor is ok.
Mar 15, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
OMG HELP!!PLEASEEEEEEEE WIERD LINE SHOWING UP
plesw see your LCD settings or remove your screen wipe if and then fit it and restart
Oct 21, 2007 | Nintendo Wii Console
Funny monitor problem
If I were you I would invest in a new video display card. Sounds your card is intermittant, because the chances of a tube type display and a TFT display having the same problem is slim to none. LOL Good Luck Please dont forget to rate this thread
Oct 20, 2006 | Samsung SyncMaster 540N 15" LCD Monitor
Televison & Video Logo
129 people viewed this question
Henry  Thomas
Henry Thomas
