I have a compressor 5 tons, when I checked the said compressor I found out that the internal parts were noisy. Please advise what would be the possible cause of that internal parts noisiness of the compressor.
  • 1,420 Answers
Contaminated oil causing internal parts to wear against each other, broken motor mount inside compressor (if Hermatic), bent rod or crank. Something that will not be an easy fix, sorry. I would use it till you lose it.
Posted on Mar 11, 2011
My Iveco eurocargo 75e16s tipper has a very noisy air compressor unit can you tell me if it needs fixing?
some times better to fit a refurbished unit
noises like that means might fail soon
Sep 11, 2016 | Cars & Trucks
Ruud 5 Ton UAKA Condensor fan running but compressor won't start. Internal thermal overload cycle.
Have you checked the wiring going to the compressor to make
sure it is not melted? Next, are you
able to put your hand on the top of the compressor? Check to see if it is hot or cold. You might have a bad run capacitor so let the
unit turn on, wait about 5 minutes, turn the unit off, and then tell me if the compressor
is hot or cold to the touch. Next, are
you comfortable with a meter?
Oct 17, 2013 | Ruud Matching Split Air Conditioner
PU8YAKD-TH MITSUBISHI UNIT COMPRESSOR INTERNAL PRESSURE BY PASSING
Mitsubishi electric Air condition model number
PU-12YAKD I not know this out door 10 ton or not and PU-8YAKD 6 ton model or not 6 ton can you please tell me
Sep 28, 2013 | Heating & Cooling
I have a 5 ton york Heat pump that I notice the compressor is too loud and noisy, what do you think is causing it?
Many possible reasons. I assume the compressor is running and hopefully is pumping freon as it is supposed too. If it is just noisey and no other problems with unit it could be worn out compressor mounts. if the compressor sounds rattley then it could be getting ready to seize due to internal wear. May be a good time to let a technician take a look. Hope this helps.
Feb 11, 2011 | Carrier 38CKC036 Air Conditioner
Ruud 4.5 ton unit comes on but the compressor is noisy and it does not cool house....can compressors be replaced or can you put more oil in them....where can we purchase A replacement...
First, check the age of the unit. If it's less than 5 years old, the compressor may still be under warranty. You would be responsible for the labor portion.
Replacing an A/C compressor is not simple and requires special tools and training. Almost any local competent A/C shop should be able to replace a compressor if that is the problem.
You might want to call for service first before going any farther.
Jul 07, 2010 | Ruud Central System Air Conditioner
New outside compressor 4 ton Ruud 13 seer unit.
Sounds like a compressor needs to be replaced. You will need a service tech to make sure of it. Sometimes the compressor can work for a long time that way. Check your warranty. Usually compressors will have longer warranty on it.
Jul 25, 2009 | Heating & Cooling
We have a fairlynew 5 ton Central Ruud or Rudd unit that it is so noisy in the yard that we can not stay out there. We thinkit is the compressor. Help
I have a new 13 seer rheem or ruud same thing. I can not here it run. Uou must have a bad compressor. Ruud put schroll compressor in and when they start to go out they will drive you nuts they are so loud. Get it changed before your warranty runs out. Ruud will change your compressor if it to noisy. No problem. Russ
Jul 20, 2009 | Ruud Central System Air Conditioner
Samsung 1.5 ton slpit AC.the out door unit is very noisy
Check to see if the noise is coming from the fan, could be bad bearings. Replace the fan motor if that is the case. If the noise is coming from the compressor, the only other place besides the fan, then your compressor has some issues and will probably stop working soon, maybe line up for a replacement before you are left with a hot house.
Jun 11, 2009 | Fujitsu 24C1 Air Conditioner
Elekta Window Air Conditioner, Thermostat won't cut off.
there is a temperature sensor try to imerge it into a hot water glass and the try again.
May 24, 2009 | Heating & Cooling
Very noisy operation
Yes....this will throw than fan unit out of balance almost the same way the tires on your car get out of balance. The wobble effect at high speed makes tons of noise.
Oct 05, 2008 | Kitchen Ranges
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
