Question about Cameras
On a JVC GZ-MG37U I can record for a while - sometimes 20 seconds, sometimes 4-5 minutes, once even 23 minutes, but then it stops and gives me a bad video playback file message. I have to repair the file and I don't lose the video, but I'm worried about recording an important event and having the recording stop in the middle. How to I make it stop doing this?
  • 2 more comments
  • Chris Ford Mar 12, 2011
    The problem is happening with 2 different brand new charged batteries.
  • Chris Ford Mar 13, 2011
    the camera is about 4 years old
    I haven't used it a lot
    it has never been repaired
    the original 707 battery wouldn't take a charge, so I just bought two 714 batteries - the charger thinks both of them are fine, and they both run the camera well
    the error happens with both batteries
    I just thought - I haven't checked if I get the error running on the AC adapter
    the camera is about 4 years old I haven't used it a lot it has never been repaired the original 707 battery wouldn't take a charge, so I just bought two 714 batteries - the charger thinks both of them are fine, and they both run the camera well the error happens with both batteries I just thought - I haven't checked if I get the error running on the AC adapter
  • Chris Ford Mar 16, 2011
    I tried running it on the AC adapter - same result. I also cleaned the battery contacts - no change. So, your recommendation is that the power connection to the circuit board is faulty and I need to take it to a JVC service center?
  • 668 Answers
Can you give me some more details about your camera such as how old is it and in recent times it had repaired or any part has been replaced? Because your symptoms indicate that camera itself is faulty. The sensor inside the camera tends to be defective.
Waiting for your reply to direct you in right direction to solve your problem.
Shane
Posted on Mar 13, 2011
  • Shane Mar 13, 2011
    Clean the metal contacts of the battery holder properly with dry cloth and then insert the new battery and check you are getting Same error message. If you still face the problem, then inner conductivity is lost between battery terminals and circuit board.Then check with AC adapter.
    Let me know the outcomes, so that I can guide you further accordingly.
    Shane
  • 3,083 Answers
This could be caused by a few things. First of all, make sure the battery contacts on both the battery and inside the recorder are clean (use a qtip and alcohol or a pencil eraser). Next, make sure the batteries are fully charged.
Aside from that, the unit will have to be serviced to fix the problem, which could be difficult to find, since it occurs spradically. Contact JVC to find an authorized service center near you:
http://support.jvc.com/consumer/support/support.jsp?pageID=5
Good luck, and hope this helps.
Posted on Mar 12, 2011
The record button and telephoto slide switch are no longer functioning on my JVC Everio GZ-MG37U. Would that be a hardware or software issue?
This is most likely a failure in the contol switch assembly and will require disassembly to repair.
This can be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Sep 10, 2011 | JVC Everio GZ-MG37 Camcorder
Lost cd-rom to install software for the jvc gz-mg37u hard disk drive
Required software cd-rom is available in JVC Accessories Store for $31.90
under following part number:
CR-ROM W/CAPTY MPEG EDIT LY35273-002A-S
Jun 03, 2010 | JVC Everio GZ-MG37 Camcorder
Jvc camcorder gz-mg37u battery lock broke
Fixya does not sell replacement battery locks and is unable to recommend sources.
Aug 03, 2017 | Video Cameras
I have a JVC GZ-MG37u Everio. It is a harddrive and its full. I need to get the videos from my camcorder onto a dvd that will work in any dvd player. Is it as easy as hoooking it up to my dvd player and...
hook it up to the front sockets on your dvd recorder ..select the front imput sockets on your dvd remote usually av3 press play on the camcorder and record on the dvd recorder.or hook it up to your pc to edit...
Sep 14, 2009 | JVC Everio GZ-MG130 Camcorder
Drivers
i lost the cd driver for my gz-mg37u jvc hard drive camcorder what shall i do?
Sep 20, 2008 | JVC Everio GZ-MG27 Camcorder
JVC Everio GZ-MG37u Cant Connect to Pc
I want driver sony handycam 700x digital 8
Sep 17, 2008 | Video Cameras
Camera Temperature
mine is an everio gz-mg37u and i get that same bulls*** on the screen at every power up. First I tried waiting a while then switching all the switches between camera and video mode, record and watch mode, etc. and one time it worked and the message went away. Haven't been able to do that since.
Now what I do is turn it on, wrap it in a blanket, leave it about 10 minutes, then turn the power off and on again. Works fine for me, and if I turn it off and then turn it back on within a few minutes before it cools down, it works fine. There has to be a messed up sensor in this thing that I can desolder somewhere......
Jun 13, 2008 | JVC Everio GZ-MG130 Camcorder
how to export video from camcorder to windows movie maker because power producer sucks!!!!!!!!!!
Feb 24, 2008 | JVC Everio GZ-MG37 Camcorder
Cameras Logo
22 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
