Question about HP Compaq Presario SR1620NX (SR1620NXEG733AA) PC Desktop
I asked this a few days ago; , I have a Samsung SpinPoint P80 SP1604N 160 GB Hard Drive in a HP compaq presario SR 1617CL I want to replace it with a larger HD, 500GB or 1TB. Can I replace it with a Western Digital 500 GB AV PATA 7200 RPM 8 MB Cache Bulk/OEM AV Hard Drive WD5000AVJB or a Western Digital Caviar Blue 500 GB Pata 16 MB Cache 3.5-Inch Internal Retail Kit DrivesWDBAAV500?0ENC-NRSNby Western Digital.. Now I am trying to decide which of these HD's to purchase. I'm not sure what is the difference between 8MB cache and 16MB cache, and what difference is in two WD 500GB hard drives, Both are 7200RPM 8MB cache only one has an AV in the # . I do watch movies online and have an LCD TV connected to my computer, I don't know if this will help in choosing a HD. Any help or suggestions would be greatly appreciated.
    Novelist:
  • 188 Answers
The specifications I found for the computer you mention indicates that it comes with a Serial ATA-300 PCI 160 GB hard disk. Serial ATA means SATA.
The drives you are selecting to buy are PATA, that means Parallel ATA, also known as IDE. PATA hard disk connectors are not compatible with SATA connectors (unless you have both buses inside your computer. Even if you do, Serial ATA devices have a better transfer data ratio than its PATA counterparts.
Maybe you should look for hard disks with the SATA interface.
The 8 or 16 MB buffer difference also presents an increase in performance - these buffers are made of electronic memory devices that are much faster than the hard disks - they are used to store chunks of data when they are being transmitted to and from the hard disk. You see, the computer is sending lots of data to the hard disk, but it is a little slow in receiving and storing them in the disks, due to the rotation of the platters, the movement of the recording heads, the search for free space area where to record them, etc. So, these data are delivered to a faster electronic memory that receives them faster, without problems and then transmits them to the hard disk little by little, at it own pace, this way accommodating the flux of data between the slower disk and a faster computer. Logically, the more memory you have in this buffer, the better!
So a 16 MB buffer would represent a better performance, if all other characteristics are the same between two different drives.
Hope this explanation might had given you some hints for your next acquisition!
Posted on Mar 11, 2011
Testimonial: "amsung's SP1604N is a 160 GB ATA/133 hard drive, with a 2 MB buffer and rotating at 7,200 rpm, it does have serial ATA I found the info at Hardware secrets, thanks so much Mike. I kinda new to this, just have replaced RAM -4G and processor from sempron to athlon 64. Now want to change HD and I have a never used XP pro OS I would like to install on new HD have found at HP the need downloads for bios and all software for SR1617cl, when I get new SATA HD I'll be asking for more help. Thanks again"
  • Dennis Mulligan Mar 11, 2011
    Samsung's SP1604N is a 160 GB ATA/133 hard drive, with a 2 MB buffer and rotating at 7,200 rpm, it does have serial ATA I found the info at Hardware secrets, thanks so much Mike. I kinda new to this, just have replaced RAM -4G and processor from sempron to athlon 64. Now want to change HD and I have a never used XP pro OS I would like to install on new HD have found at HP the need downloads for bios and all software for SR1617cl, when I get new SATA HD I'll be asking for more help. Thanks again
  • 35 Answers
Yes, either of these drives will work. The cache is not all that important it is just where data is stored temporarily in case you have to access it again soon after a file is written to the hard drive. The best thing you could do in this case is see if your motherboard has a sata connection which I would assume it does and buy a sata hard drive. It will be much faster than either of those drives, just make sure you also get a sata power adapter if your power supply doesn't already have one and a sata cable.
Testimonial: "Thank you so much I thought I would like to get a SATA HD and my motherboard does upport it however I was stumped on the power hook-up, where to get ."
Samsung SP1604N Jumper setting
Find the following image hope this helps
Jun 22, 2012 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Check for damage parts, then check the connector between the driver and the casing. if you have self damage warranty get it replaced.
Jan 06, 2012 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
My computer will boot to my samsung SP1604n Hard drive but there won't be and windows screen. how do i fix this?
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test or replace all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
Dec 14, 2010 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Just need a samsung sp1604n driver
Any drivers needed will be on the samsung website, but unless you are using an old motherboard and windows xp (may need drivers loaded off a floppy drive) no drivers are needed.
If you are using Vista, your problem may lie in your motherboards bios, it may need an update
Jul 17, 2010 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Jumper setting for hard drive
Dear Friend,
To make Master Hard drive Look here..To make Slave unplug jumper from the Hard drive..... Hope this Helped you..Thanks for Contacting FixYa...
May 21, 2010 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Harddrive will not boot
Try to scan it with demo version of R-Studio or GetDataBack.
Oct 20, 2008 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Error message: HD521-2W
this error is basically a fatal error. you will endd up needing to replace your hard drive soon but if you dont like doing a recovery every few days and loosing your information all the time replace the hard drive
Mar 30, 2008 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Lost 12GB
check the partition table, maybe their unspecified disk, delete all and recreate a new partition. Otherwise use create the remaining as a logical drive so that you will not re-installed the Operating system including the driver of your hardware
Aug 15, 2007 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
HP Compaq Presario SR1620NX (SR1620NXEG733AA) PC Desktop Logo
143 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
