Question about Goldstar MV-1526 Microwave Oven
Microwave turntable and light inside oven just turned on automatically and it wont stop and the only command (buttons) that works is the clock. I've unplugged it and plugged it back in and the problem is still there.
    Brigadier General:
  • 8,909 Answers
It sounds like either a relay contact/suppressor or Triac has failed on the control panel or even a door switch.
Posted on Mar 11, 2011
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
No Light and the turntable is not working
Open your microwave completely unscrewed but make sure it is disconnected from the power; check all the other fuses inside, if it doesn't fix the issue then take it to a pro to get this fix.
Jan 03, 2014 | Emerson MW8102SS 1100 Watts Microwave Oven
The turntable keeps rotating when the door is opened - Panasonic NN-T994SF
You probably have a shorted main relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic NN-T994SF Microwave Oven
Everything works (clock, timer, inside light etc.) but not the fan, turntable and will not heat. It stopped while heating lasagne.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Sep 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable won't turn
Look at the front panel, at the bottom, in the middle.
Identify the button labeled "Turntable On/Off".
Push it.
Slap yourself on the forehead.
Next time you fumble to turn of the light in the dark, push the right button.
Dec 05, 2009 | LG LMV1630ST Microwave Oven
No heating, turntable does not turn, but clock & lights work.
Check to make sure the plastic on the shelve holders or tuntable guide did not wear and expose metal. If these holders or brackets are wore and exposed metal it shorted out your micro wave. They need to be replaced and a fuse needs to be replaced inside the control panel,
Sep 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave quit
I would suspect either door switches or an intermittent control circuit board, either of which can be repaired. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure over time. I have a text file on my site called "doorsw.txt" which helps in diagnosing and repairing door switch problems. You can find the file via a Google search. It will help you check and replace the door switches if you or an able friend is so inclined. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see fairly often, and we repair them for only $32.50 nationwide.
Oct 12, 2006 | Panasonic NN-T990SA Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
