Question about Refrigerators
Every couple of days there is a puddle of water coming from unit..shut off water source and still leaked water?! HELP!
    Sergeant:
    Novelist:
  • 185 Answers
Is the hose from the freeze compartment in the drain pan? Or is the drain pan leaking? The unit is going into a defrost and that is where the water is coming from. It drains into a drain pan where it evaporates over time......Check the drain line and the drain pan. Is there ice in the bottom on the freezer maybe the drain is pluged inside and the excess is seeping out the door during defrost. Hope this helps....
Posted on Mar 11, 2011
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
Why do I have a puddle under my fridge every couple days but no sign of a drip or leak?
If it is an automatic defrost fridge the it will have a hose draining down into a container under the fridge, make sure it is draining where it should and has,not become dislodged. Some have a small tray with either pipes inside it or an electric heater. Some have a container sitting on top of the compressor, both of these are used to evaporate the water.
check to make sure there are no holes in the water catcher.
if you have an electric heater that is not functioning then the container will be already full of water and at each defrost cycle will overflow onto the floor.
Sep 08, 2014 | Refrigerators
Water\coolant leaking from engine after shutting engine down
It takes a lot more than a small leak to consider your engine as "totaled"
Have the system pressure tested and carefully inspected. Every leak has a source. some are easy to find, some are a bit more difficult. A shop can use a fluorescent dye and a black light to locate the source if you can't.
I'd check the corners of the intake manifold and timing chain housing. Also, check the hoses again. A small pin-hole can squirt coolant far away from the hole itself and is often very difficult to see.
Aug 03, 2010 | 1997 Jeep Grand Cherokee
Water leak from under refrigerator
Only two possible sources for a leak one is an ice maker, the other is defrost drain water. Either way it is only 9 months old and still under full warranty!! Call sears and have them come and look at it! I have seen a few of these units with cracked drain pans so be persistent if the tech cannot find a leak, have him pour some water into the pan to see if there is a crack.
good luck and save yourself some stress.. You have a warranty to cover this:)
Jun 11, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water leaking on the floor
Typically condensation (water leaking) is from a bad seal on your doors. Doors can be warped in transit, from not being leveled or items that were crushed in on the seal. First off, get a level and level your unit front to back, side to side. After letting it settle for a couple of days, then take a piece of paper and place around the door and close. Now pull the paper out - you should have good resistence. If the paper slips out easily, that is your problem area. See if you can pull the seal away from the door to reseat it. Sometimes pulling it out, then closing the door to reset will take care of your problem. Try these solutions.
Aug 30, 2009 | Kenmore Refrigerators
Hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Mar 01, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Rain water leak
The most common source of this kind of leak is the windshield, have a glass shop check the sealing around the glass
Sep 04, 2008 | 1992 Mercury Grand Marquis
Refrigerators Logo
374 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
