Question about Weather King 10AJA2501AH Air Conditioner
Replacing filters Do I have to replace filters on my weather king a/c? If so, where do I buy the filters and how do I replace them?
  • thanks02 Oct 13, 2008
    need a help finding where to replace the air filter on the weaterking furnance.
    An expert who has answered 500 questions.
  • 540 Answers
Not above the fifth grade!
Posted on Aug 30, 2008
Why does furnace overheat and the limit switch shuts it off?
Are you in the North East region of US?
For the pass 6 days I saw a lot of postings for furnace and humidifier failures.
Partly is because the weather but the root cause is lack of maintenance.
User think LIFETIME Electrostatic air filter is maintenance free.
That is not true.
It's wash-able and need to be handle with care.
Inspect the air filter and replace it..
Lack of air circulation cause the furnace frame from burning efficient (BLUE FRAME) to orange / red color.
Over time,the temperature sensor will be coated with carbon deposit and record a higher temp reading.
They circuit will activate the fail safe and not allow the igniter to start on.
In your case,limit switch shut itself off.
Here is a LINK to pictures of Weather King temp probes and sensors.
A clean filter and temp sensor will save you money.
Dial back the furnace to 65F until you can get hold of the filter and clean the sensor.
==== If the MODEL TAG is still in plain view then please post it on reply.
Please keep me posted on the fix via email.
Jan 27, 2011 | Weather King Heating & Cooling
I have a Weather King Acclaim Gas Furnace and I cannot find where to change the filter.........can you help me?
On some of these, the filters are located outside of the actual unit in the silver metal duct that attaches to the bottom half of the furnace. It has a 1" cut into it where the filter just slides vertically into place. If you need additional help, call Weather King directly at (479) 646-4311.
Sep 11, 2010 | Heating & Cooling
Weather King Acclaim 2 Gas furnace efilters
If your furnace is easily accessed in the basement or a closet etc. then likely the filters are located either in the bloer compaertment (the small panel on the furnace) or in the ductwork attached to the furnace. There should be a removable cover. The size varies dedending on the size of your system. When you remove the old one it should be printed on it or you can measure it.
If your furnace is in the attic or a crawl space then you probably have filter grill(s) in your return air. Usually centrally located in the home.
Filters should be changed as needed depending on how you use your system but usually every 30-90 days.
Jan 17, 2009 | Weather King 12AJA4801AH Air Conditioner
Weather King kicking on an off
An easy way to tell is look at your t-stat if it has emer heat, heat , cool and off on it it is a heat pump system and if you only have heat ,cool and off on the switch it is electric heat
Dec 03, 2008 | Weather King Heating & Cooling
Where can I find weatherking acclaim II filters
Your best option is to contact your nearest wheather king/Rheem dealer. They may have replacements. The filter store online, they offer any size and cheap too!
Nov 30, 2008 | Weather King 12AJA4801AH Air Conditioner
Weather King Air Conditioner
The best way to find the size of the filter is to use a tape measure to find the size of the filter cavity. Remmeber, most filters come in even numbered inches, and you can buy a "cut to fit" at The Home Depot. Ask for "Hogshair".
Jul 26, 2008 | Heating & Cooling
Filter size
Thats an A/C, what is the indoor unit model #? Does it have a filter box? If so what size? If not do how does your filters sit in the unit?
Jun 23, 2008 | Weather King 12AJA4801AH Air Conditioner
Weather king a/c system
To be honest these manufacturers are all about the same, The differance is going to be a good install vs. a bad install. Just make sure to shop wisley when you are looking for an installation contractor.
Hope this helps Ya please rate me.
Jun 19, 2008 | Weather King 10AJA2501AH Air Conditioner
Not cooling predictably
Possible causes are dirty filters, dirty condenser coil, dirty evaporator coil, or low referigerant charge. Any one of the conditions will affect heat transfer.
Check the filters in your indoor unit, If they seem to be clean and replaced on a regular basis, your evaporator coil is probably in good shape. Unfortunatley on some Weather King models even checking the evaporator coil is not possible due to the extensive amount of referigerent lines that block access to the coil without some major work including evacuating the refrigerant.
The most likely cause is a dirty outdoor condenser coil. On weather king models you will have to remove the casing that surrounds the coil because is is built in such a way that the condenser coil cannot be properly cleaned with the casing in place. Once it is removed make sure breaker is switched off and clean the coil with a water hose.
If your outdoor coil is not dirty then it is a refrigerent problem.
Jun 10, 2008 | Weather King 10AJA3601AH Air Conditioner
Jan 16, 2008 | Weather King 10AJA6001AH Air Conditioner
Weather King 10AJA2501AH Air Conditioner Logo
103 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
