Question about Mackie MR8 150W 8 Active Two-Way Studio Monitor MR8
One speaker hums very loud with nothing plugged into it i own the mr-8
    Novelist:
  • 168 Answers
If this monitor is humming without nothing connected to it, maybe the electrolytic capacitors from its power supply are bad - they are responsible for filtering the fluctuation at the output of the internal voltage rectifiers that transform the AC input voltage into a DC voltage to feed its internal amplifier.
When they fail, the supply voltage for its internal amplifier that should be flat, continuous, now presents a pulsating profile, according to the mains frequency (generally 60 or 50 Hz, depending on the country you're in). So, the output of the amplifier will be varying at the same rate, producing the humming.
Another possibility is that one internal cable connection that should be shielded is now disconnected or loose and is picking the hum from the internal power supply.
Anyway, maybe you should take it to a service center and have it checked.
Hope this info may help you!
Posted on Mar 11, 2011
Peavey xr 8600 about 6 yrs old used weekly heard a loud pop them a low emiting hum no sound comes thru .... is it time for a tech ? or dose it sound like an easy fix like fuse or something power on board...
Check the caps in the PSU, these give out over time although not normally when used regularly. You may be lucky and be able to see one or more with bulging tops. If you can replace them and all MAY be OK. Whilst in there check for any visible signs of anything burnt or blown. If it looks too bad or there is nothing obvious it's a trip to the repair shop for certain.
Oct 05, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
My sc40r amp started humming really loud after i had turned it on... it played perfect the night before... but when i went to go play it this morning it started humming really loud then stopped and began...
You take it in for electronic repair. Unless you are electronically adept at troubleshooting and repair this is not DIY. Probably one side of the PA transistors has shorted. You can blow the speaker if you keep trying to use it this way.
Sep 24, 2011 | Rogue SC40R 40W 2x8 Stereo Chorus Guitar...
I have a Eupoport EPA 900 system. Recently I started getting a consistent, low pitch and fairly loud hum out of both speakers. The hum adjusts with the volume, and I have tested it with various working...
Is the hum there with NO input cables connected? If not, you have bad cabling. Make sure you use only XLR to XLR mic cables and not the junky ones with a 1/4 inch plug that are for Karaoke machines. These devices usually use switching power supplies and do not have the power supply originating hum of older equipment. If the volume control adjusts the hum, then the hum originates previous to the control which is either in the preamps or the external inputs.
Aug 25, 2011 | Behringer Europort EPA900 Ultra compact...
Hi, i have a heil talk box. plugged it to a amp head and i think it was to loud. the bulb burnt so i went to a car shop and got one tht fit(not sure if i needed a certain one or not) anyways, now it wont...
Your amp for this should be no more than a 50 watt amp AND have another 8 ohm cabinet connected in parallel. You MAY have blown the tiny speaker in the Heil as well as a protection bulb. Use an ohmmeter to check continuity of the speaker driver voice coil.
Jul 06, 2011 | Dunlop Ht1 Heil Talk Box
When I turn it on, the speaker has a loud buzz. The 8" sucks in at that time.
The amp driving the 8 inch has shorted to one of the power rails of the power supply. With the short, the voltage is dragged down to the point that the filter caps can't keep it up so you hear the hum or buzz. DO NOT operate it as it is driving a high current into the speaker and will blow the voice coil...Take unit for repair.
Apr 26, 2011 | Mackie MR8 150W 8 Active Two-Way Studio...
I get a hum whether the guitars plugged in or not...same problem with my GH100...happens at different locations...so that rules out outlet wiring...
A low hum may be perfectely normal in these, however if you can hear it four feet from the speaker that would be too loud.
Filter capacitors are always suspect, but an oscilloscope is the correct tool to diagnose the problem.
Mar 06, 2011 | Laney GH50L 50 Watt All Tube Guitar Head
Very loud ground hum when turned on
If nothing is pluged into the speaker and it makes that noise. It is not a ground problem. You either have a blown amp or remotely some bad connection at the large filter caps.
Nov 30, 2010 | Mackie MR8 150W 8 Active Two-Way Studio...
I have troubles with a to little speakersound i have checked the fuse and its okay its a new one for me this pmp5000 can you tell me i have 1000 watt speakers do they not play loud with this
These can develop around 500 Wattts or so into speakerss that are 4 ohm.
If your speakers are 8 ohm the max power to each is around 250 Watts.
The efficiency of your speakers may reduce the loudness . The power rating of your speakers really has nothing to do with the loudness, only the power that can safely be sent to the speaker.
Sep 15, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Loud speaker hum then blows fuse
Hi there. The final output IC (big and black with 15 pins? attached to heat sink) is shorted and needs to be replaced. If you can still see color bands on R63, it should still be good.
Thanks
Paul
Jul 12, 2009 | Music
I have a set of peavey scorpion sp5xt's one works fine but if i plug into the other one ,in full range, only the horn works,
Horn and speaker combo cabinets have an electronic component called a "crossover". The horn and speaker both work off different electrical signal frequencies. If you can take off the back, or get inside by pulling the speaker, check for a small circuit board mounted inside the box or on the speaker or horn. Check for a broken wire or loose connection of the crimp connectors.
A common problem with speakers, often the cone, or paper part of the speaker will come un-glued or separated from the magnet "voice coil". This happens when played too loud, when it's commected to the wrong impedance, or if the signal was shorted and "overdriven" (usually sounds like an awful buzz that's really loud).
Always make sure your output impedance matches the impedance of the speaker. Most auto stereos are 4 Ohms. Older home stereos are typically 8 Ohms. Musical PA gear varies between 4, 8, and 16 Ohms. Peavey gear is typicall 4 Ohms, but some older models are different. The Ohm rating is the amount of the resistance in the circuit. If your speaker is 4 Ohms and you plug it into an 8 Ohm circuit, you can destroy the speaker and sometimes the crossover circuit board.
Good Luck.
Jim
jimmydsmith@cox.net
Phoenix, Az
Jan 09, 2009 | Music
Mackie MR8 150W 8 Active Two-Way Studio Monitor MR8 Logo
288 people viewed this question
Top Mackie Music Experts
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
