Question about Kenwood DVF-3060
I have a Kenwood DVD CD player that all of a sudden stopped working. When you put in a cd the counter seems to go faster than 1 second at a time and the music doesn't play. When playing a DVD it just makes lots of whirling noise and no audio or video. The player is afew years old. Any suggestions?
  • Kenwood Master
  • 467 Answers
Sounds like a nasty and possibly costly failure, due in part to a fault in the secondary stage of the switchmode power supply. Being a 'few years old' I doubt in today's market it would be economical to repair at component level, and I doubt replacement boards would be available.
You can always submit the player to a service centre, get a quote on the likely cost(s) if it can be fixed, then you can decide for yourself afterwards whether or not you wish to go ahead with their repairs. This is up to you.
One idea is for you to replace every electrolytic capacitor in the power supply. This may or may not restore the correct voltage rails to the servo circuits in the player, in turn restoring audio/video as well as normal counter displays. If you do, make sure each capacitor is correctly valued and voltage rated when replacing. Some values may need to be increased as originals may be unusual. This is an inexpensive and simplest way of tackling it; you might be lucky. (Electrolytics are polarised - i.e. they have a stripe down the side = negative pole)
However, if you don't believe you can DIY with this, then the only other alternative due to the possible age of this unit, is to buy a new player. The difference between the cost of a new machine and the repairs to your old one could be significant. Because it is not a recorder, in this case it might be cheaper to simply replace the whole player.
Posted on Mar 11, 2011
I just purchased a Rowe AMI CD-100a. It was a barn find. Once I learned to initialize, I tried to play individual tacks or entire CDs. For each track, the unit picks the CD, places it down on the player...
Could be the power supply voltage is low, possibly due to a bad capacitor, it seems that when the counter advances it is pulling the voltage down enough to cause the problem you are experiencing. If you can select a disc in the service mode, the counter should be inactive, and you can see if the disc will play through.
Sep 29, 2013 | Wurlitzer Jukebox CD Player
My kvt617 will not accept the cd or dvd what is the problem and solution?
I have this head unit and found that the load tray is a little off,I use a second cd/dvd to assist in loading and it has worked everytime.put the disk in you want to use and as its loading give it a light bump with the second disk...Hope this helps
Aug 27, 2010 | Kenwood KVT-617DVD Car DVD Player
CD player doesn't work...
most cd players have a reset button underneath the faceplate. try hitting that and see what happens.
Mar 30, 2009 | 2003 Toyota RAV4
Kenwood kvt m700- playing cds
The M700 is purely a monitor so you will not be able to control play, pause, stop, skip, FF or RWD. I use my DVD player as a CD player and have to use the DVD remote to change tracks.
Mar 27, 2009 | Kenwood KVT-M700 Car DVD Player
Kenwood KDC-X589 seems like the CD player doesn't put out sound
you have to change the cd read setting it might got set to cd read 2 it needs to be cd read 1 in standby mode press menu button scroll through with track button till you see cd read and set it to cd read 1 if not in standby mode try in cd mode same steps
Jul 03, 2008 | Kenwood KDC-X589 CD Player
Help please
DOES IT EVER SHOW YOU A COUNTER, NUMBER OF TRACKS AND TIME? ALSO DOES IT DO THIS WITH DVD AND AUDIO CD?
Mar 08, 2008 | Kenwood KVT-717DVD Car DVD Player
Kenwood KVT-617DVD
hi kenwood go's off when i put it on to dvd
Jan 16, 2008 | Kenwood KVT-617DVD Car DVD Player
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Mecha error
Mecha error is a Mechanical Error. This means that this is an actual physical malfunction of the unit. Sometimes pressing the reset button can realign some of the mechanics but most often this is a problem that requires to be serviced.
Feb 03, 2007 | Kenwood KVT-717DVD Car DVD Player
Kenwood DVF-3060 Logo
55 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
