Question about Kenmore Ovens
We have a Kenmore 316065304. The door is open, the lock wont disengage, and we can't do anything with the oven. We don't have the manual either.
4 Suggested Answers
SOURCE: oven door lock
Hold oven door light in while touching clean cycle enter up arrow or down arrow then hit cancel. door will unlock.
Posted on Nov 18, 2008
  • 491 Answers
SOURCE: I canceled clean cycle and opened oven door, just
SOUNDS LIKE MEMORIE PROBLEM UNPLUG WHILE STILL ON AND LEAVE OVERNIGHT
Posted on Jul 18, 2009
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore Oven door won't unlock
It appears your door lock mechanism has failed in this instance.
First - unplug the unit for 40 minutes and re-try.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Kenmore stove the oven wont come on it says dr
The DR error can mean that the door lock is enabled (or the oven believes it is). If the oven door was open and the Clean button was pressed, this can happen. Try pressing Cancel with the door closed. If the door is open, press the oven light button in and press Cancel. Try unplugging the oven (or flipping the circuit breaker to off) for a few minutes to reset the error.
If these don't help and the oven is not locked, then the control unit probably needs to be replaced. If you add a comment with the model of the oven, I may be able to direct you to the parts.
If your oven is still under warranty, contact Kenmore. I hope this helps.
Jul 03, 2014 | Kenmore Ovens
Putting door back on but hinge wont release to put back on
Hi Susan, this is AP! Thank you for your post.
I understand you are having trouble putting the door back on your Frigidaire wall oven. Without knowing exactly how you removed the door I cannot say with certainty how to reattach the door. However, when removing the door did you pull up the lock located on both hinge supports and engage it in the hinge lever hooks? You might have had to apply a little downward pressure on the door to pull the locks fully over the hinge lever hooks. Then grab the door by the sides and pull the bottom of the door up and toward you to disengage the hinge supports. If so, then to reattached the door grab the door by the sides; place the hinge supports in the hinge slots. Open the door to the fully opened position. Disengage the lock from the hinge lever hooks on both sides. Make sure the hinge supports are fully engaged before unlocking the hinge levers. Then close the oven door. There are instructions with images to remove and replace the oven door in the owner's manual. I hope this information proves helpful for you.
Mar 14, 2014 | Frigidaire FEB30S6D Electric Single Oven
Can't disengage oven door lock
Lock disengaged on its own after a day. Oven is now clean, everything working properly.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
May 31, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Try throwing the electrical breaker off and then on to see if it will reset. If not you could put it through another cycle to see if its a jammed armature. However either the door lock motor armature is jammed or the motor is the problem or the solid state did not recognize the cycle was over. If you open the breakers and remove the covers to access the mounting screws you can work the unit out of the wall. Be sure to place some heavy towel or card board on the ground to keep from damaging the floor. Watch placement of your hands and depending on your fittness level you may need a hand pulling and replacing the unit. Test the electrical supply to ensure that its not energized. Then try disengaging the lock armature. IF YOU OPT TO REMOVE THE LOCK THEN THE UNIT SHOULD NOT BE USED IN THE CLEANING CYCLE, EVEN THOUGH THE UNIT SHOULD NOT FUNCTION WITH THE LOCK DISENGAGED, YOU NEVER KNOW ABOUT ELECTRONICS AND IF IT RAN IN THE CLEANING CYCLE SOMEOEN COULD OPEN IT AND GET BADLY BURNED. SO DONT DO IT. You should be able to order the parts needed on line at this website. http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears Best o Luck :?) DRRXR
Feb 01, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Locked door light flashing
I had the same problem with a gas kenmore oven. I played with the lock mechanism (opened it a little more manually) and it fixed the problem...
Jan 12, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Kenmore oven locked
Hello dktshopping,
I know you probable don't want to hear this but in you circumstance, I think you would be better off to contact a repair professional. Those oven door locks are meant to keep the door from opening during the oven's self-cleaning cycle. They are both mechanically and temperature controlled so that the door can not be opened when the oven is 950 degrees. It sounds to me as though something is not releasing to allowing the locking mechanisim to disengage from the door even though the lever is in the unlock position. The unit will probably have to be taken apaprt to remedy the problem. Good luck.
Nov 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore locked
The www.managemyhome.com website has some troubleshooting options when the door wont unlock. Good luck. Also you can download the whole manual online it you have your model number. Mine was inside the drawer under the oven.
Apr 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
DOOR LOCK WONT OPEN
do both of you have a digital display? if so are you getting any codes that f- with a number?
Nov 20, 2007 | GE JGRP17 Gas Single Oven
Oven door locked
you would have to remove oven.remove top panel and disengage latch assembly if you are a tech.
Jun 23, 2007 | Kenmore 30169 Electric Single Oven
Ovens Logo
170 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
