Question about Toshiba Audio Players & Recorders
I want to turn the mic off on my laptop but use a mic that is with a headset. Is there a way to turn one off and leave the other so it will come on when plugged in?
  • 3,400 Answers
Just go into your preferences, ->audio input -> and switch your audio input preferences from internal mic to external mic.
Posted on Mar 11, 2011
Philips shm1900 headset on Lenovo thinkpad t430 with windows 7
It sounds like you are still using the mic on the laptop. Because you are far away from it, it sounds like echo.
Make sure the phillips headset is selected in the Windows mixer.
Make sure you are plugged into the mic jack on the laptop.
Make sure the mic is not muted. This is a default setting.
Apr 02, 2014 | Philips SHM1900 Headset
When i talk on skype so no body hear my voice
Try your Sound settings, Recording/Playback/Mic device settings, you may need to setup for headset.
Feb 20, 2013 | Acer Aspire 3680 Laptop
The mic does not work but I can gear people
Looks like you are using more mic's on your system.(The internal mic within a laptop?)
See within the operating system if the correct mic is activated.
You must always callibrate a new mic within the operating system.
Good Luck.
Aug 03, 2011 | Logitech (980174) Headset
Most people I try to talk to using the bluetooth complain that they can't hear me even whn I almost shout.
It could be that your mic is clogged up or dirty, or that you have a loose or broken wire. No way to know. If you try to clean the mic with a damp cloth, do not run it under water. Surgery drinks will leave crystals in the mic, which do not allow sound through. If it still won't work you may need to replace the headset.
Good luck from Headsets Direct!
Sep 28, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Mic not working (plantonics headset)
Your exterior mic MAY have been the one ACTUALLY working rather than the one on the headset. Some mics require a battery for the mic part to work, Not sure about your particular Plantronics. If it has a battery, then check the battery as the receiver part does not use it but the mic MAY use it.
Oct 06, 2009 | Plantronics Radio Communications
What type of headset do I need?
You're laptop has already the mic, so need for you to buy headset with mic. But, make sure that your laptop built in mic is still working.
Regards,
Jeep Brainy
Sep 20, 2009 | Computers & Internet
Headset help
Do you have a headset mic combo? If so, make sure they are plugged in to right ports and the volume for mic and headphones is turned on. This can be done by right clicking speaker icon in taskbar and selecting the 2 different functions.
Dec 28, 2008 | HP Pavilion dv6000z Notebook
Acer aspire 4720z Built-in microphone only records loud static
You did great troubleshooting for your laptop. If the sound is fine and good for the headset, your sound card is probably not the problem. The driver aspect, should not be the problem either if it works with your headset. So herein lies the dilemma...the problem is most likely due to some physical componenent between the built-in mike and the computer case itself. You should take it to a laptop repair shop and see what they can do. It has nothing to do with the software or the sound card. It is the physical component of the built-in mike and speakers. Get that checked out and you should be good to go!
Nov 15, 2008 | Acer Aspire 4720 Notebook
Mic is not recognized
Just had the same problem occur on a laptop with same mic. Did the exact same thing yours did, I turned the mic boost on and ran the hardware test three or four times and it finally picked it up. Hope this helps.
Oct 21, 2007 | GE (98980) Headset
73 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
