Question about Maytag MER5550 Electric Kitchen Range
Actually a kenmore model 911.95292991 electric stove the 'oven on' light is flashing and I cant find a manual to tell what the flashing means. it appears to be a simple consistent flash. in other words no pattern such as 3 blinks then a long wait then 3 blinks. if you could tell me which code number that is (or where to find an online manual for this stove), what it means... THANKS
SOURCE: gemini electric range from maytag
Just unplug it and plug it back in. It will reset it.
Posted on Jun 05, 2008
  • 3 Answers
SOURCE: Maytag Gemini Electric Kitchen Range
maytag double oven model # mer6770acw code f1-1 and
f 1-3 appears on the panel when using the ovens ofcourse when it gets warm or hot the ovens stop working .thanks for help
Posted on Sep 09, 2008
ginko
  • 19396 Answers
SOURCE: Maytag MGR5770 Gas Kitchen Range displays OFF and nothing works!
That is normal, whenever you cut power the range goes in Off mode, that is a safety standby mode. The same as you first installed the kitchen.
No faulty thing and no need to take apart anything, do not disassemble the appliance.
The usual procedure to activate back the kitchen range is by downpressing the timer main wheel.
If this does not work, then there must be a different command, check the user instructions , or try playing withthe controls.
Posted on Nov 07, 2008
aborcass
  • 2651 Answers
SOURCE: ELECTRIC STOVE MATAG MODEL#MER6872BAS
F1:-8 Keypad Shorted Check to see if steam or other moisture is getting into clock assembly. Replace keypad if necessary
Posted on Nov 09, 2008
  • 492 Answers
SOURCE: Stop self-cleaning
Reset the curcuit board by pulling the plug for 10 min. This will reboot the board and force it out of the self clean mode.
Posted on Apr 30, 2009
Kenmore electric range model 790 door lock light flashing
Hi, When door locks, This is when oven is in self clean mode. After the heat has cooled down the door should release again. If this does not work try turning the power off to the stove (breaker) This should reset the stove to normal. Call a repair man if this continues. Good luck.
Jun 01, 2015 | Kenmore Kitchen Ranges
I need a manual kenmore slide in range electric 90152
I don't believe that is the actual model #. Pull out the drawer and look for a sticker on the frame of the stove. Also open the oven door and look for a sticker on the frame there. If its a Kenmore the sticker should have something similar to "970-", "956-", "110.", "646-". Take the full model number and Google it. If its a "970-" you should be able to find the manual here: http://b2b.frigidaire.com/support/manuals.asp
Apr 12, 2014 | Kenmore 90154 / 90152 Electric Kitchen...
What causes a kenmore electric stove to flash f10
usually that is associated with a runaway temp depending on the moddle
you would need to replace the sensor
goto sears dot come typee in your model number
they will ship you the part
Sep 29, 2009 | Kenmore Kitchen Ranges
My question concerns a Kenmore glasstop electric oven (model #790.95200100). While operating the oven at 450 degrees and the back right burner at level 5, I heard an audible "pop" and saw a flash of light...
After letting the stove cool, I pulled the entire unit out from the wall and discovered scorch marks on the wall. Opening the back panel revealed a simple fix: the "element on" light module had shorted and was visibly scorched and melted. Looks like a simple replacement (and some wire stripping where the leads fused). Stove currently works with the affected wires capped off (while I await a replacement module).
Sep 14, 2009 | Kenmore Ovens
I have locked my Kenmore self cleaning stove, now it won't open
Sorry you gave the sereial # for the oven. Need model #. Here is an manual that might work for you. cout and past in address bar.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0309524.pdf
Or you can go to this web sight and look up your oven.
http://www.managemyhome.com/mmh/answers/Answers.action#l4q106688
Good Luck
Dec 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Elite Electric Range, Display stuck on LOC
I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
Feb 03, 2008 | Kitchen Ranges
Maytag MER5550 Electric Kitchen Range Logo
93 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
