Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
I WANT TO INSTALL THE WASHER AGITATOR /CAM HOW DO i GET THE OLD STUFF OFF
I DON'T EVEN KNOW WHAT SIZE THE BOLT IS CAN YOU HELP? I AM OVER 60 AND ON OXYGEN(AND FEMALE) BUT I NEED TO HAVE A WASHER THANK YOU IN ADVANCE
I finally found the right socket wrench and the screw came right off. I assembled the agitator parts as per instructions. the whole project didn't even take 30 minutes. the washer worked perfectly. I washed a heavy load to be sure it could still agitate. In my opinion anyone can do this.
Posted on Aug 01, 2008
Top agitator, not being spun by motor
If the problem is just the the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. Most of these parts are commonly sold as part of their in-store inventory.
Read through the information provided and let me know if you have any questions. Please include a complete MODEL NUMBER with any questions you may have. I hope this is helpful to you.
Jul 08, 2010 | Kenmore 22422 Top Load Washer
Agitator problems..
If the problem is just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
Thank you for posting your model number. The part numbers you may need are as follows:
Item 10 - If just replacing the Agitator Dogs: 80040.
Item 9 - If replacing the entire Cam Assembly: 285809 (includes the Dogs and the Cam Thrust Bearing).
Item 22 - Spacer Thrust Bearing: 3951608
All these parts can be viewed under the "Agitator, Basket and Tub Parts" section of the parts resource websites I listed for you. The last digit of your model number is a "zero" (0), vice the letter "O".
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 26, 2010 | Whirlpool LSQ9030P Top Load Washer
Bolt inside agitator has come loose there is a spring in it all of it is unloose
You are referring to the agitator bolt and agitator cam assembly. Whirlpool manufactured washers (such as Kenmore) use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) has come loose all that you should have to do is retighten the agitator bolt and snap the center post cap (or dispenser) back in place. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
If you have any parts that require replacing, such as a worn cam assembly or agitator dogs, the following link epxlains what these parts are, and how to replace them:
The part number for the agitator dogs is included in the link provided. For a little more you can purchase the entire cam assembly, which includes the cam, thrust bearing, seal and dogs.
Replacement parts can be purchased at any of the following websites:
repairclinic.com
The first three sites I have listed have helpful exploded view parts diagrams to assist you in locating and identifying the parts you may need. These drawings can also be helpful in helping you reassemble your agitator.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope you find this information helpful.
Mar 31, 2010 | Kenmore 24032\24036 Top Load Washer
Auger in top load washer don't turn when in washing cycle but does spin in spinning cycle
This sounds like a problem with the agitator. Or the drive for the agitator. If you can hear the motor running but do not have any agitation then something in the agitator may be stripped. If not then you may have a timer or electrical problem. Let me know if I can help in any other way.
Ken
Mar 17, 2010 | Roper RAS8445KQ Top Load Washer
The agitator is loose and "clunks" as it is washing. How to fix?
You may have a worn agitator cam assembly, worn agitator dogs, or a loose agitator bolt.
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by either worn agitator dogs, a worn agitator cam assembly, or a loose agitator bolt. The following link explains what the dogs are and how to access and/or replace them. It also explains how to access the bolt and tighten (if necessary):
The part number for the dogs are included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you aren't sure, or have additional questions about this repair, please post back with your complete model number (located on a nameplate along the wash tub opening under the lid) and let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Feb 03, 2010 | Roper RAS6233KQ Top Load Washer
Top agetator is not working what do i look for
well if the model number thats attached to this call is even close theres still 20 sub-models from ther. anyways your agitator sits upon a plastic drive bell, you can remove the agitator by pulling up sharply upon the agitator (sometimes a belt looped under the agitator provides a better grasping surface), then you can see and touch the drive bell, which is held in place by a 7/16th bolt.. that drive bell is indexed to the transmission drive shaft by splines that sometimes/often wear out allowing the agitator to spin sorta freely..
give that a shot and let me know..
have fun, and good luck,
ttfn
Jan 31, 2010 | Hotpoint VBXR1090D Top Load Washer
The aggitator is not working right ..it seems to spin like a nut on a stripped bolt.
If this is a Whirlpool manufactured washer, the problem is very simple, inexpensive and easy to repair.
Whirlpool has a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs, worn agitator cam assembly, or a loose agitator bolt. The following link explains what the dogs are and how to replace them:
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12.
If you have any questions about this repair, please post back with your complete model number (located on a nameplate along the wash tub opening under the lid) and let me know. I hope this helps you.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator not working
Hi, This agitator is a 2 piece agitator. Can you see if the lower half on the agitator is working properly? If the lower part is working and the top is not, you will need to change the agitator dogs. If neither half are working, you might be having transmission issues.
To change the dog kit, re,ove the top cap on the agitator and locate a 7/16" bolt. Remove the bolt and the agitator will lift out. Pull the agitator apart and the dogs are 4 small plastic pieces inside the top half of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator does minimal agitation
Hi Omni,
The Agitator "dogs"/cams have given up the ghost and need to be replaced. Access to them is easy. Before starting the repair, have this part in hand.
Here's a tool list;
1.) small flat screwdriver (to remove the top part of the agitator)
2.) 3/8" ratchet
3.) 8" X 3/8" extension (for the ratchet)
4.) 7/16" socket
Take a gander at this pic... you'll be going after #10 'cause that's the problem.
All you gotta do is remove the top parts from the agitator to access it. See #2 in the diagram? That's the bolt holding the agitator to the transmission shaft. Remove that, then lift the whole agitator out of the tub. Now place the agitator on the floor and put both of your feet on the base. Now lift the agitator (#3) off the base (#4). Place one of your hands into the opening of the top of the agitator (to hold the cam (#9) in place) then turn the agitator over. The cam will slide right out.
Now you'll see the cam "dogs"... little white curved plastic doo-hickeys. All you gotta do now is install the new cam assy. and rebuild the agitator! Cool, huh? All it takes is about $15 bucks in parts and ~20 minutes.
Let me know if you have further questions. And don't forget to rate my solution as "FixYa"! Thanks, BB
Apr 14, 2009 | Whirlpool LSQ9610L Top Load Washer
Maytag Atlantis Washer - MAV6200AWW will fill and spin, but wont agitate. Also lost the bolt going down into the agitator. Anyone know what size it would be?
bolt has 1/2inch head but dont know the thread size is an orderable part 3 to 5 dollors, may not agitate since agitator not on shft to turn
Apr 17, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
