Question about LG 42LC2D 42 in. LCD HDTV
The TV does not always come on from standby when using the remote to turn it on. The problem was intermitant a few weeks ago now it occurs the majority of the time. Tou just have to keep trying then all of a sudden it responds
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 100 Answers
It sounds like your remote contacts are failing. You can
  • Open up the remote (check for screws under the battery compartment, you may also need to carefully pry apart the case
  • When open carefully remove the rubber button from the circuit board and clean the contacts on board. ( an eraser on the back of a pencil does wonders)
  • Snap the remote back together and you should be good as new
If this is too cumbersome you can always pick up a universal remote as a replacement as well.
I hope this helps
Magoo
Posted on Mar 11, 2011
A few weeks ago I turned on my Thomson Wysius Tuner 42WB02S and the red standby light flickered from red to orange then green before going back to a flickering red light. The TV screen then displayed a...
Dear Mrs Burger,
I have exactly the same problem with my Thomson, have you solved your problem yet? If so, what was wrong with your tuner?
Best regards
Sam
Dec 07, 2010 | Televison & Video
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
WHEN I TURN ON MY L32 I GET NO PICTURE. I GET BLACK SCREEN THEN LOTS OF COLOR, REDS ,BLUE ,ALL COLORS IN DIFFERENT PATERNS THAT KEEP CHANGING. SOUND IS PERFECT AND I CAN CHANGE CHANNELS AND VOLUMEAND...
It sounds to me like it's stuck in service mode.There is a button combination with the remote to return it to normal. I would call Vizio support and they should be able to help you.
I think it's a combination like [volume -], [channel -] and power but I could be wrong.
Dec 19, 2009 | Vizio L32 32 in. LCD HDTV
Can't get my Panasonic LCD out of Standby.
I only have two solutions. Either, turn the tv on from the tv. or try checking the tv connection. If that doesnt work maybe the remote is out of battery.
Sep 14, 2009 | Televison & Video
SONY KV34HS510 always worked perfectly but today it wouldn't turn on by remote or button on TV. It makes the same "click" sound which it always did before coming on but it just immediately clicks again to...
You need to bring it to a TV technician. There is a relay inside the TV which can be blocked by any few errors that may occur in your TV, for protection. Only a tech may discover the problem.
May 25, 2009 | Televison & Video
TV flickers intermitantly
loose con some where in the set very time consuming
Dec 03, 2008 | Televison & Video
Power on problems
Having to press the power button multiple times before the set comes on is usually caused by low standby voltages in the power supply or bad connections on the printed circuit board. The "D" board is not your problem. Most likely there is bad capacitor in the 9 volt standby supply.
Nov 14, 2007 | Televison & Video
Re: Sony KV-24FS120
your problem in system control ic section related to stand by pin check ckt related to stand by section in remote ic check power to system ic loose coniact in remote or system ic thanks
Sep 09, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
LG 42LC2D 42 in. LCD HDTV Logo
Computer Repairing
Computer Repairing
