Question about Car Audio & Video
I hAve a alpine type s sub it dont sAy how many watts it is
  • 35 Answers
Most type S's are 150 watts rms, depending on the size.
Posted on Mar 11, 2011
Need help wiring two 10" alpine type E subs to a alpine 500 watt monoblock amp
Just connect both sets of wires from the subwoofers to the same speaker output terminals on the amplifier. Make sure you keep the positive and negative wires together. This is called parallel wiring. The Type E is a 4-ohm, single voice coil subwoofer, so wiring them like this will give the amplifier a 2-ohm load, and the power produced will be divided between the two subs.
http://crutchfield.custhelp.com/rnt/rnw/img/enduser/Mono_2-4OSVC.jpg
Jul 16, 2015 | Alpine Car Audio & Video
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
What is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Jan 31, 2012 | Alpine Type-R SWR-1242D Car Subwoofer
I have the MRP-M1000 amp. I want to hook up 2 alpine subs to this amp. Which alpine subs would be the best for this amp? Please be specific with ohms and watts.
Your best bet will be to wire 2 subs in parallel to the amp. Each sub should be rated for at least 300 watts rms at 4 ohms. This will give you a total impedance of 2 ohms, and your amp will put out 600 watts rms at that impedance. That way, each sub will receive 300 wats rms. I would not recommend wiring subs in parallel, as you will need two 1 ohm subs at 300 watts rms, which are harder to find and will be more expensive. A parallel circuit is the most efficient way to do it.
Feb 23, 2011 | Alpine MRP-M1000 Car Audio Amplifier
I haw alpine mrp-m350 amplifier how many sub can i
Hook up the MRP-M350 to one 4-ohm sub, and you get 200 watts RMS; connect a second 4-ohm subwoofer and the power output increases to 350 watts! All that juice means that your subs won't just be loud, they'll sound clean and thumping.
Apr 08, 2010 | Alpine MRP-M350 Car Audio Amplifier
I have 2 alpine r type 12's hooked up to a kicker crossover and a NRG 2200 800 watt amp. they are wired series and parallel. when i turn it up the subs sound like the are fluttering. what is going on.
well my friend either your amp is not powerful enough to push your subs or you have a sub that is shorting out cause i just had the same problem with my 2 15 kicker cvr competition subs
Nov 04, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
I have a set of Alpine Type R 12 inch subs... I have a 1500 watt amp powering them but when I turn the music up, the bass cuts out. Where should I start looking for the problem?
ground is loose(most likely amp), battery running low, subs might be damaged? feel free to keep me in touch if problem occurs more after checking grounds and power source and subs. Also might need to re-tune your head unit and amp?
Jul 03, 2009 | Alpine Type-R SWR-1042D Car Subwoofer
System cutting out
Pull the subs out of the box and check the connections... Check to see if the wires running from the connectors on the sub itself to the voice coil... had a JL 10 that had a frayed wire to the voice coil system would cut in and out. Hope its helpful
Mar 30, 2009 | Alpine SWS-1240 Car Speaker
Alpine amp and subs questions
it will depend on how you use the 2 alpine subs,, do you know what there individual impedance is [ ohms ] and how you intend on wiring them,,,in series, in parallel, in any case you must maintain the min load in order to load the amplifier properly,,,otherwise the amplifier will operate improperly and allow DC [ direct current ] to pass and fry your subs...so what I really need is more in formation
Jul 15, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
