Question about Kenwood 1050SW Speaker
Kenwood 1050 sw remote control doesn't work even with new batteries & can't switch between movie or music mode in the front switch.
3 Suggested Answers
SOURCE: indicator light not working and humming noise
your circuit board is bad not repairable i have the same prob but not kenwood they said it would cost more then its worth.
Posted on Mar 31, 2008
Could it be solved by reversing the AC Plug on this device, matching the other inputs? Hope your board is not blown.
Posted on Dec 17, 2014
Pertaining to my Kenwood stereo control amplifier kc-206
Turner password was activated by remote.
Try downloading using the model number the deactivating password.
Oct 23, 2016 | Audio Players & Recorders
Using without parking break
Hi James,
Page 27 of the installation manual (http://www.wwstereo.com/_files/155788/documents/Kenwood--Manual.pdf) shows a connection to the parking brake light circuit. It is the Light Green wire labeled "PRK SW" shown below.
If it is connected the way it is drawn, the PRK SW wire is connected between the lamp and the switch that opens and closes depending on the position of the parking brake (set or not). 12 volts is always present from the battery to the top of the lamp. It passes thru the filament to the wire that goes the top of the parking brake switch. So, when the brake is OFF or disengaged, the lamp is off and 12 volts is present on the PRK SW wire to your Kenwood GPS. When you set the parking brake, the ground (symbol is the funny slanted lines under a horizontal line) just under the brake switch passes through the switch and changes voltage at the PRK SW to "ground" or 0 volts. When this happens, the ground on one side of the lamp with 12 volts on the other side of the lamp - make is turn on.
So, what does this mean? Simply tie the PRK SW wire to any grounded metal and the Kenwood will think the parking brake is always set - for as long as it is tied to ground. You can check it with a simple voltmeter to be sure. Set the meter to 12 volts or more, touch black lead to ground & the red lead to the PRK SW wire. Kenwood should only work when at 0 volts (brake set). Release the brake - meter shows 12 volts & the Kenwood shuts off.
I hope this helps & Good luck!
Apr 09, 2014 | Kenwood DNX570HD
Can't find the right code to control my wharfedale L19T please
I can help you with your URC-1050 Universal Remote Control issues.
I recommend using the One For All URC-1050 Code Search feature to find the compatible codes to control all the features of your Wharfedale TV.
I hope that helps.
_______________________________________________
One For All URC-1050 Manual
One For All URC-1050 Code List
One For All URC-1050 Code Entry
Jun 23, 2010 | One For All URC-1050 Remote Control
Need code for fisher tv using one for all urc 1050 remote contrcol
The URC-1050 codes for Fisher TVs are: 0154, & 0159.
For complete instructions on entering the URC-1050 remote codes, please refer to my posted Fixya Tip One For All URC-1050 Code Entry.
I hope that helps.
One For All URC-1050 Reassign Key
Jan 04, 2010 | One For All URC-1050 Remote Control
Need code for sanyo tv One For All remote.
The URC-1050 codes for Sanyo TVs are: 0154, & 0159.
I hope that helps.
Nov 02, 2009 | One For All URC-1050 Remote Control
Can I get a code for a One For All remote control urc-1050bpb01 for a sylvania tv
The URC-1050 codes for Sylvania TVs are: 0054, 0030, & 0171.
I hope that helps.
Oct 09, 2009 | One For All URC-1050 Remote Control
Kenwood control amp KC-206
Sounds like a low voltage to the front panel as the indicators are there such as control window illumination is dim and the remote does not function.
The remote sends an invisible signal to a detector just behind the front panel and if the signal from the remote is nice and strong from your new batteries in the remote then it must be the panel electronics.
I have found that if you clean the output panel of the remote with a damp cloth and the same to the front panel glass you may be lucky. Just Damp please not dripping in water!!!!!
If ypu keep the amplifier system very clean then this wont be the problem...But this action has worked on TV's with remotes...
If this doesnt work then a service is due....sorry....no quick fix..
Cheers YOU BEUT
Oct 26, 2007 | Audio Players & Recorders
59 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
