Question about Refrigerators
I have a GE Model number GSS23WSTASS side by side refrigerator and when I open the door, it smells like something is hot or like something is burning. What could this be? I doesn't smell while the doors are closed and also it still works fine. thanks Bonnie
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 155 Answers
The first thing I would check is the light bulb and light bulb diffuser.
If the bulb was replaced with either the wrong shape or the wrong wattage (higher) the bulb could be touching the disfuser (shade) or some other part of the mount.. if the bulb is too high of a wattage the heat could damage the mount and shade..
I believe that is a 60 watt appliance bulb. (soft white)..
Also this model uses a "special" light bulb for the defrost cycle. If you unit is very frosty on the inside.. frost build up could cause the fan to stop running.. you should hear a fan running when you open the freeze side. If that bulb was burned out. you would have a frost problem regardless.
You didn't mention which side smells like this.. chances are it's the fresh food side.. again.. check the bulbs..
The last thing would be a circuit board in the door.. but doubtful.. go for the simple stuff first.
Even a wrapper or food item may have become lodged between the bulb and the shade/difuser.
Posted on Mar 11, 2011
I have a GE Profile "Artica" side-by-side refrigerator model PSC23MGNA - BB. Recently the refrigerator door has begun swinging all the way open ... 180 degrees ... and banging into the...
if you look down at the bottom of the freezer door you'll see a door stop,two 5/16 inch screws hold it in place,the stop on the fridge door must of broke.you can switch it from the freezer to the fridge door for now until you get a new one.part number is WR02X13425 and it's around 5 dollars.give your parts store the model number and they will take care of you,or go here,pick any topic here,put your model number in,to the right of the model it will as model or part number,pick model and click on it and your machine will come up,click on fresh food door,your part is numer 12 and you can order it from sears if you want.let me know how you make out
Feb 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile 21 cu ft. goes continuously except upon defrost, "once a day" for about 30 minutes. Unit cools both on freezer side and refrigerator side (ice cream ok and milk ok). Repairman...
open the doors and feel the middle strip.if that's hot check the condenser fan to make sure it's running and clean out the coil in the back.pull out the machine,remove the bottom panel,on the right side you'll see the coil,with a shop vac vac off the coil and then put it on blow and blow out the coil,that's the only way to clean this kind of coil and make sure the fan is blowing back there.let me know what you find,also send the full model number,open the fridge door,look at the right wall near the ceiling and you should see the model number.
Jan 23, 2011 | GE Profile Side-By-Side Refrigerator with...
How do I find my model number
On a GE open the fresh food door and it should be on bottom right front corner
Apr 18, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Freezer smells like ether
Hi,,
If the freezer smell like ether, you need to do this
  • Remove spoiled food
  • Clean refrigerator interior with a solution of hot water and baking soda
  • Clean the door seals
  • Remove breaker strips and check for wet insulation
Regards
PCmania
Jul 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator gets extra hot on top and side
The only thing that I can think of that would cause this is heat strips that are placed around the door frames to prevent moisture from forming around the doors. The way you have explain what is happening is an indication that the strips are out of control. If you can find the model number located on the bottom of the fresh food compartment door frame behind door get that for me. The problem is unsafe and should have your full attention until resolved. The parts cannot be replaced and can short out. If you have a local dealer or someone to talk to about the problem would be a good
idea. If you can find model number let me know. The model number above your post appears to be incorrect. Thank You Sea Breeze
May 24, 2009 | Whirlpool GD2SHGX Refrigerator
Smell only when fridge is open
try putting in newspapers to draw out smell
Mar 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
ISO refrigerator door handle
Your original repairman must have looked up a similar model without the snack door. The handle of couse would have also been listed, but this is difficult since A. You do not give your model number and B. (maybe not as bad) we don't know what model number he used when he ordered your door(s). Please list the complete model number of your refrig. (from sticker inside fresh food compartment) and I'll try to help.
Aug 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side freezer refrigerator
That is called a heat strip. Used to keep moisture down around the door gaskets. You will need to roll unit out, take lower back plate off and check to see that the condinser fan is turning when compressor is on. If not,replace fan motor
Jul 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
260 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
