Question about Kenwood KDC-X794 Car CD / USB/ MP3 Player
I have a 1985 chevy monte carlo and I have ran a wire from my fuse box for a constant n my cd player will not keep memory and my memory is fine on the cd player.iv had several cd players in this car and this has happend everytime.wen I turn my car off all settings are never saved.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 100 Answers
You must have tied into an Accessory fuse and not a constant. Typically Cd player/radios etc will need both an Accessory tap as well as a constant tap.
Test the voltage on the wire and if it's constant you will have 12VDC without the key in the ignition You will also need a tap where there is 12VDC ONLY when the key is in ACC mode (or ignition on)
I do not have specific details on your CD Player but consult the manual on adding both of these connections,
I hope this helps
Magoo
Posted on Mar 11, 2011
  • harleyr312 Mar 11, 2011
    I will do that.I have it ran to radio acc.if I had a meter I would use it.I just like to kno were to run the acc and the constant.that sounds like it would wrk.thanks magoo.
Horn relay
it should be in the fuse box.
Oct 05, 2013 | 1985 Chevrolet Monte Carlo
Stored 1985 chevy monte carlo 305 v8 a year ago ran perfect.tried to start today wants to start will not catch.any suggestions ?
BAD GAS!!! Empty tank, lines and and float. Get tarnish out with carb cleaner and put in fresh gas with chemical to dry lines of water/whatever. Replace fuel filter.
Nov 28, 2009 | 1985 Chevrolet Monte Carlo
I need a diagram for my 1980 chevy monte carlo
'80 Monte Carlo, a good ride. A Chilton's book is a good investment. It will show you wiring and vacuum hoses and how to do the brakes, etc.
May 03, 2009 | Chevrolet Monte Carlo Cars & Trucks
Audio display says check cd
This may be a bit late to help, but I just had the same problem yesterday. Same car (2000 Monte Carlo SS), but mine is just the CD/radio stereo (no cassette). I was able to solve it by pulling the fuse for the radio (it's in the right-side panel) and letting it sit for a minute. After putting it back in, the CD player made the disc ejecting sound one time (no "check CD" message) and stayed off. And now it seems to be working fine. We'll see how long it lasts, though.
Mar 25, 2009 | 2000 Chevrolet Monte Carlo
Fuse
The 88 Monte came stock with am/fm or am/fm cassette so my guess is your head unit is after market, implying that there may be two in-line fuses on the units power leads
1) 12+ volt Un-switched constant feed (memory)
2) 12+ volt Switched feed (operation)
If you can not locate these fuses from under the dash, then you may need to remove the head unit to inspect the wires that connect to the rear for the in-line fuses.
When you reinstall the unit, be sure to make those in-line fuses accessible from under the dash.
Good luck
Aduz
Mar 14, 2009 | Car Audio & Video
1985 Chevy Monte Carlo, need body info.
the complete nose up to the front doors are bolted on.the only thing that gets a little tricky is the lower radiator support. just take youre time and it can be all disassembled and rebolted with out too much trouble.
good luck chris
Mar 11, 2009 | 1985 Chevrolet Monte Carlo
No heat or a/c in my 1987 chevy monte carlo
I'm guessing you lost the blower motor....there is a heavy gauge single wire by the trans fill tube that powers up the blower. The conection is usualy melted might be a red wire
Nov 19, 2008 | 1985 Chevrolet Monte Carlo
Where is the Fuse bloock locatred in a 1981 Chevy Monte Carlo?
Hi ledfooted_dr, the fuse box on located on the left side of the steering column below the dash good luck
Nov 12, 2008 | 1983 Chevrolet Monte Carlo
Kenwood KDC-X794 Car CD / USB/ MP3 Player Logo
73 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
