Question about Arris High Speed DSL Modem
All lights on modem green, then all go off for minute or so, then back on. brand new out of box today. Worked fine first hour but then I moved computer across room, now this problem. Could modem be bad or do i need to reset or start over?
    Scholar:
  • 97 Answers
When ALL the lights go out, even the power led, there is either a problem with the modem itself (a malfunction) or with the power supply. I'm assuming the move of your computer is unrelated to this issue. Since your modem is new and still under warranty, I's best to contact the store that sold you the modem right away.
Posted on Mar 13, 2011
D-Link Router, Model DI-524 is not able to register IP address. My cable company did maintenance yesterday and this morning unable to link to internet with Router hooked up to modem. Apparently no good...
Sometimes when ISP's do maintenance the DHCP servers re-assign new IP numbers. When you have symptoms like yours it's because the modem, router, and computer are working off previously assigned old IP numbers that may have then been re-assigned to other customers modems after the maintenance. Same with the router. Rebooting your equipment causes them to pull new IP numbers and things start working again.
So, usually a reboot will fix it. Turn off the computer(s). Turn off or unplug the power cables from both the modem and the router. Keep them off for 3 or 4 minutes. Leave the data cables connected. Plug the power to the modem back in FIRST. Give it a few minutes to come up. Any lights should be green. If the lights don't come up green on the modem you'll need to call the cable company.
Second, plug in the router and let it come up. Again, lights should be green. Lastly, turn on the computer.
That should do it. If not, please post back. There are other things to try.
Jan 13, 2011 | D-Link AirPlus DI-524 Wireless Router
Yesterday had Cable Internet hooked up at new house--when done modem had all lights green, and wireless router connected and worked fine. Now router won't connect to Internet, and USB connection direct to...
Sounds like a problem with your cable connection. Check your coaxial cable, and the splitter from where the cable enters your home. The tech will use a signal meter to measure the quality of your cable, and then replace the wiring if necessary.
Jan 04, 2011 | Motorola Computers & Internet
Only 2 lights coming on and can't get on the internet.
It depends on what two lights. Could mean a variety of different things. 2 lights tends to mean your box is receiving a signal and usually has internet access. which would lead me to believe either your router/Nic or Ethernet cable is bad or miss configured. Can also mean water or some foreign debris has gotten into a connection on the way to the cable box/a main line is bad. With ought knowing which two lights its almost impossible to narrow down though. Your best best would be to call Mediacom's Tech line and see if they can ping your modem if they can see it then its more then likely a problem on your set up.
Jul 15, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have moved to new home. I am using 2wire wifi
you can check if the ethercable is loose or if you have a spare ethernet cable (rj45) you can replace the one that youre using
Jul 14, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
D-Link DIR-600 Router got a new account with att and my dlink wont work. it worked fine untill I had to set up a new account because of a late payment. I tried the install disc but no go all green lights...
Turn off everything and wait for a few minutes and turn on the modem and wait for the lights to be steady then turn on the router and lastly the PC... make sure also that the connection of the modem to the router is correct ( modem should be connected to the WAN/Internet port on the router)
Mar 27, 2010 | D-Link DIR-600 Router
Won't run
You have the RED RING OF DEATH, you have to send it back to the Microsoft people and they will send you back a new one
Dec 25, 2008 | Microsoft Xbox 360 Console
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
LC 32D43U power and OPC green light flashing set does not come on
hey i have had the same problem but i unplugged the tv for awhile about a half hour and then plug your tv into a different wall outlet if you can and should work. It worked for me, i had it plugged into a surge protector then i unplugged it from there, let it sit of half hour then plugged into different wall outlet and worked. so try that and see if it works.
Dec 29, 2007 | Televison & Video
Siemens Speed Stream 4100 modem - worked last week - now no lights
This modem is for AT&T broadband only and requires AT&T software to function.
Jan 10, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Arris High Speed DSL Modem  Logo
93 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
