Question about HP 8500 Premier All-In-One InkJet Printer
Fatal error installtion - HP 8500 Premier All-In-One InkJet Printer
    Scholar:
  • 56 Answers
Download the latest installer software for your printer on the link below and save it to the Desktop.
ftp://ftp.hp.com/pub/softlib/software12/COL31041/mp-77031-3/OJP8500vA909_Full_13.exe
Check that you have the latest version of Adobe Flash installed on your PC.
Next download and install Revo Uninstaller from the link below.
http://www.revouninstaller.com/download-freeware-version.php
Disconnect your printer from your PC.
Run revo and use it to uninstall your printer software. Right click on the icon of the program you wish to remove and select Uninstall. During the process you may be asked to delete registry entries, just select all and then click delete. Do the same for any left over files and folders. Once the uninstall has completed, reboot the PC.
Temporarily disable any security software ( Antivirus and Antispyware )
Now try running the software installer from your Desktop by right clicking the installer and selecting 'Run as Administrator'. Do not connect the printer to the PC until the software asks. If everything install Ok, remember to enable your security software.
Hope this helps.
Best wishes,
Posted on Mar 11, 2011
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
How to fix Fatal Error on printer
What operating system? HP has had problems in the past with some installs not working properly. Check the install disk for a program called SCRUB.exe. Unplug the USB cable from the printer, run SCRUB and this clears all traces of printer out of registry. Then rerun the install, making sure that you run the install as an administrator and that you disable any virus protection and firwalls while performing the install. Also make sure you follow the instructions about when to attach the USB cable as starting install with the USB attached will cause problems.
Sep 13, 2014 | HP Photosmart Premium C309g All-in-one...
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
My pc`s screen is blue and it sais stop:c000021a ,is there? anything I can do to fix it
hello there
here is some information that should be able to explain this error and how to fix it ok?
best regards michael
  1. How to troubleshoot a "STOP 0xC000021A" error ... presents advanced troubleshooting steps for the STOP 0xC000021A error. ... STOP: c000021a {Fatal ... Note Most STOP 0xC000021A errors occur because Winlogon. ...support.microsoft.com/kb/156669
  2. "STOP: c000021a (Fatal System Error)" Error! RE: "STOP: c000021a (Fatal System Error)" Error! Ya, thats what I thought I might have to do ... RE: "STOP: c000021a (Fatal System Error)" Error! just input the ...www.msghelp.net/showthread.php?tid=66202 - 52k - Cached
  3. How I fixed my Windows XP Stop c000021a {Fatal System Error} with ... How I fixed my Windows XP Stop c000021a {Fatal System Error} with Knoppix Linux. 2008 March 14 ... Message: Stop c000021a {Fatal System Error} The Session ...healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-f... - 53k - Cached
Sep 16, 2009 | Microsoft Windows XP Professional With...
Iomega HDD Fatal Error 05
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Jul 05, 2009 | Iomega ScreenPlay
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Instalation problem
go Here: read and fix
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00229852&lc=en&cc=us&lang=en&rule=21085&product=3177566&dlc=en
Jul 04, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Emachine will not start up it says fatal error regeristery not updated, then turns off
Linux and UNIX ld command help -z defs, Force a fatal error if any undefined symbols remain at the end of the ... which are marked lazyload will not be loaded at initial process startup
E-mail CHID: 5369 Unfortunately we were unable to find anything about the Fatal Exception error message you are encountering we suggest you go through the basic fatal.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | E-Machines eMachines Desktop PC
HP 8500 Premier All-In-One InkJet Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
