Fax machine is not answering calls and when faxes are sent it comes back as being sent but there is no duration, no pages, and no answer for a result
    Genius:
  • 2,120 Answers
What is make / model?
Posted on Aug 31, 2008
The answering machine and the fax come on at the same time when someone is calling in - therefore they cannot leave a message due to all the squealing
I don't see a specific question being asked, but I assume you want to know how to be able to stop the answering machine and the fax machine from answering calls @ the same time.
The easiest solution would be to order another telephone line and use it for the fax machine.
The only other option would be to purchase a device that "listens" for the polling beep that fax machines make and, if it hears it, sends the call to the fax. If it doesn't hear it, the call is sent to the answering machine.
Here is an example:
http://www.usr.com/products/telephony/telephony-product.asp?sku=USR4000
Apr 09, 2011 | AT&T ATT1739 Digital Answering Machine
I have a Model MF 4150 , Serial No. JVM 73593 The Basic Guide that came with the purchase does not provide the necessary information. I have a phone on the same line as the fax machine (plugged into...
I'm going out on a limb here, and guessing it's a Canon imageClass MF4150... If not, please disregard this solution.
The advanced manual can be viewed / downloaded / printed here, directly from Canon:
http://gdlp01.c-wss.com/gds/0900006459/imageCLASS_MF4150_Advanced_Guide_EN.pdf
To stop it from interfering with the telephone conversation:
Issue: Fax interrupts telephone conversations in answering machine mode (AnsMode)
Solution: Setting the Receive Mode - ICMF 4150
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif> to select [5 FAX SETTINGS], then press <OK>.
  3. Use <la.gif> or <ra.gif> to select [3 RX SETTINGS], then press <OK>.
  4. Use <la.gif> or <ra.gif> to select [3 RX MODE], then press <OK>.
  5. Use <la.gif> or <ra.gif> to select the desired receive mode, then press <OK>.
    round_note.gif - For [AnsMode], make sure an answering machine is connected to the machine.
    If [AnsMode], [FAX/TEL], or [DRPD] is selected, you can select some settings as below:
    [AnsMode]
    --- [AnsMode CHK TIME] (select time from 10 to 30 seconds for the answering machine to start playing outgoing message after receiving a call)
    --- [FAX DETECT TIME] (select the duration from 10 to 70 seconds for the fax to detect)
    [FAX/TEL]
    --- [RING START TIME] (select the time from 0 to 30 seconds for the phone to start ringing after receiving a call)
    --- [F/T RING TIME] (select the duration of ringing from 10 to 45 seconds)
    --- [F/T SWITCH ACTION] (select the action the machine will take after the ringing ends, Receive or Disconnect)
    [DRPD]
    --- [NORMAL RING]
    --- [DOUBLE RING]
    --- [SHORT-SHORT-LONG]
    --- [SHORT-LONG-SHORT]
    --- [OTHER RING TYPE]
  6. Press <Stop/Reset> to return to the standby display.
Apr 25, 2008 | Office Equipment & Supplies
I have changed from a desinated fax line to sharing a phone and fax line. the fax machine rings along with the phone however the fax does not answer. i was told to purchase a ring decipher but cannot...
Your fax can share the line with your phone, but it needs to be set to answer or not, depending on your equipment and choices.You can download the manual from Brother here. The receive modes are explained on page 5-1.
If you're often out when faxes or phone messages might come in, you probably need to plug an answering machine into the back of the fax (the EXT. jack) and put the fax in FAX / TAD mode. (TAD stands for Telephone Answering Device. Be sure the TAD is set to answer before the fax does. The fax will pass the phone call through to the TAD, and if it hears the beeping of another fax sending, it will cut off the TAD and take the call.
See the manual for more info and other options.
Feb 15, 2011 | Brother IntelliFAX 2600 Fax
I sent fax and it comes back with the error no answer, I called the other end and it did not even ring, how can we fix this?
Call the fax number from a regular phone, if you don't hear fax tones, it isn't a fax machine or they have fax option turned off.
Aug 17, 2008 | Office Equipment & Supplies
Cannot recieve faxes
you need to watch during ringing period need to click ok or press what ever message says.
Dec 03, 2007 | Lexmark X5150 All-In-One InkJet Printer
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Problem with the fax
Introduction Review the information below to determine why faxes cannot be sent or received. Review the symptoms below carefully and then select the symptom that best fits your problem. If the solution links you to a different document that does not resolve the problem, return to this document to continue troubleshooting. Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received.
  1. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  2. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  3. If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products.
    1. Visit the HP Support and Drivers Home page .
    2. Select Download drivers and software .
    3. Type in your model number (HP PSC 2210xi for example).
    4. Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models.
    5. On the software download page, select your Windows version.
    6. Locate and select the firmware update.
    7. Follow the directions to download and install the update.
  4. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (bpu04072).
  5. If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (bpu50333) to learn how to correct these problems.
  6. If the problem still exists, continue troubleshooting in the Faxes cannot be sent or received or you're not sure of the problem section below .
Oct 24, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Fix my fax
Oct 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Will not auto detect incoming faxes
Review the information below to determine why faxes cannot be sent or received. Review the symptoms below carefully and then select the symptom that best fits your problem. If the solution links you to a different document that does not resolve the problem, return to this document to continue troubleshooting. The fax machine doesn't receive or send a fax and prints an error report (bpu02549). Faxes cannot be received but they can be sent . Faxes cannot be sent but they can be received . Faxes fail intermittently or with only one fax number . Faxes cannot be sent or received or you're not sure of the problem . Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup. If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products. Visit the HP Support and Drivers Home page . Select Download drivers and software. Type in your model number (HP PSC 2210xi for example). Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models. On the software download page, select your Windows version. Locate and select the firmware update. Follow the directions to download and install the update. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (bpu04072). If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (bpu50333) to learn how to correct these problems.
Aug 02, 2006 | HP OfficeJet 6110 All-In-One InkJet...
49 people viewed this question
jasbo
jasbo
