Question about Princeton Digital VL1918 Monitor
I have no sound on my Prinston VL1918 monitor now that I hooked it up to my new ASUS computer. Do I need to download a driver?
  • 11,361 Answers
No sound driver is needed for the built-in monitor power speakers (just think of it as a Powered PC speakers built-into the monitor). Are your PC sound card and driver and setting OK? Try feeding the monitor with sound source from MP3 player to see if it works OK, To repair the amplifiers in the monitor will not be worth it since you can spend the same amount for a good set of Powered PC speakers instead with much better sounding.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Mar 11, 2011
Cannot get HDMI output to work to my flat screen when while using DVI to monitor
you must download the Driver correctly, the driver can not be installed or corrupted.. See your company supplier from PC and proceed to download. or you have instaled the driver is corrupted.
Uninstalled and installed again with new version, see if the play and plug the driver is o.k or corrupted proceed with the same technic before
God bless you
Sep 25, 2012 | ASUS Essentio CM5570AP003 PC Desktop
Hello I can't get anything on my screen except
Your PC is putting too high resolution for he VL1918 to display.
You need to set your PC video out put to the native resolution of the VL1918, which is 1280x1024 @60Hz.
You will have to hook up your old monitor (crt type?) and set the new resolution.
Or boot up in safe mode (hit f8 during boot up), and set the resolution to 640 x 480, reboot into regular mode, then rest the resolution to 1280x1024 260Hz.
Also watch out for bad caps in this monitor: http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Apr 07, 2010 | Princeton Digital VL1918 Monitor
Need to download drivers for a princeton vl1918 HELP!
open the internet and open the link www.softwaredriverdownload.com/princeton_graphics_vl2018w_driver.html - United States and you can instantly download the drivers
Mar 28, 2010 | Princeton Digital VL1918 Monitor
My monitor is going on and off, even if its not connected to the computer. its stays on for 10 seconds saying no signal. then shuts off n comes on again right away for another 10 sec, ect.
matteson1914, If unplugging from wall outlet and then plugging it back in 1 minute later will not stop (correct) the problem you have, then I would suspect (as always) the "switch-mode-power-supply" has a serious problem. Whenever an lcd with CCFL backlighting starts doing very strange and weird stuff, I would suspect the power supply as the culprit and look at it first! If your display is a VL1918 then you WILL need to read all the other posts by clicking on "VL1918 (black) monitor" that is highlghted in blue. If you do any capacitor replacement make sure they go in (installed) correctly(++ - - ) and that new ones are rated for 105 deg cenitgrade (not 85c) If installed wrong they will fail immediatly and you will need to do-over!!!! 12fixlouie
Nov 12, 2009 | Princeton Digital VL1918 Monitor
Princeton vl1918 flashes on than off
See previous solution for Princton Monitor cycling on and off.
Solution: Change out 3 capacitors.
Jul 15, 2009 | Princeton Digital VL1918 Monitor
I have a Princeton VL1918 LCD monitor. Need help
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If you don't see any bad capacitors then the next thing would be bad CFL (backlight tubes) in the screen itself. If it is that then the monitor needs to be replaced because of the tech skills needed to replace then. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 29, 2009 | Princeton Digital VL1918 Monitor
Vl1918 backlight replacement
this is not a driver issue. There is a hardware problem. You will have to replace the lights, or purchase a new monitor.
Please rate me.
Thanks and good luck, let me know how it turns out.
Feb 02, 2009 | Princeton Digital VL1918 Monitor
Princeton 19" lcd vl1918 BACKLIGHT replacement
On the bottom of your monitor or on the right side is a set of buttons one is for brightness and contrast try to reset the brightness and then contrast. If this does not work you may need a new monitor.
Jan 25, 2009 | Princeton Digital VL1918 Monitor
Will Princeton monitor VL1918 support NVIDIA GeForce 6150 SE
Hi Alvie
I Just checked the specs on both the card and the monitor. It should work no problem. If for some reason you notice some lag or flicker in the monitor, go to this page and download the updated ForceWare graphics drivers.
http://www.nvidia.com/object/winxp_169.21_whql.html
Mar 27, 2008 | Princeton Digital VL1918 Monitor
Driver downloads
http://www.princetongraphics.com/site/support_drv.htm
NOTICE: Your monitor does not require any drivers to function. If you have problems changing resolutions, color depth, or refresh rates, Please consult your video card manufacturer for a video driver or support. Your system will not identify the monitor if video drivers is not installed properly.
You might want to check your video card drivers. Hope this helps.
Mar 25, 2008 | Princeton Digital VL1918 Monitor
Princeton Digital VL1918 Monitor Logo
123 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
