Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
My samsung projector tv's light lamp keep shoting on and off what could be the problem?
    Scholar:
  • 90 Answers
Http://www.youtube.com/watch?v=ARNVqW6qngE&feature=related hi there, above is the link to a video clip. Please watch it is the same idea in replacing the lamp for your Samsung TV. defective lamp need to be replaced especially when it manifest defects for you to enjoy your same old TV. Please rate and vote, good day
Posted on Mar 11, 2011
Samsung HLS5687.Replaced lamp,turned on TV the light goes on turns off. The projector boards continues to beep then tv powers off. Color wheel does spin. Not sure what the beeping is.
Did you check the ballast for the lamp? It provides the high voltage/energy to excite the lamp (no filament) into operation. If it does not work properly neither will the bulb.
Great set - I have the 5685.
Mar 06, 2016 | Samsung HLS5687WX/XAA
Have a 50 inch samsung projection tv model hlt5075sx/xaa lamp code bp9601653ap132w turn tv on lamp stays on for approx 20 seconds then 3 blinking lights on right bottom side start blinking if it is the...
The blinking lights will be flashing a code.....
Can you please indicate the sequence of the flashing lights, as this will determine what needs to be done to fix your fault.
Cheers,
Jun 16, 2011 | Samsung - Projection TV replacement lamp...
My 48" Samsung Projection TV (approx 5yrs old) has white spots forming all over the screen....what is the fault?
Hi...
It appears that the "light engine" has problems
It may be dust in the unit or electrical issues on 1 of the modules on the :light engine
Find a TV tech...It's the best way to handle it
Aug 19, 2010 | Samsung - Projection TV replacement lamp...
Light bulb not working after colorwheel replaced
Same thing happened to me (By jschmidbauer on Jan 14, 2010). How did you fix it????
Jan 14, 2010 | Samsung - Projection TV replacement lamp...
My samsung projection tv picture is going dark
Hi
the main reason is could be that you lamp is old and needs to be replace, Phillips lamps will give you from 6,000 to 8,000 lamp hours and if you get a generic lamp that will give you from 3500 to 4500 hours let me give you an insite of the lamp technology:
Background UHP Lamps are used widely in DLP and LCD projection displays. The lamps are not extremely complicated
and provide a light source for your television or projector display. Philips lamps have very low failure rate
and are often blamed for another faulty component such as a bad ballast, color wheel, light engine, or
cooling unit. The lamp itself is encased in an enclosure, meant to hold it in place and connect it to the ballast. How It Works The lamp itself typically uses AC current and about 15,000 volts to ignite the lamp's mercury vapor gas. The gases inside the lamp react when electricity charges up the mercury gas creating very bright light. The voltage drops to keep the flow of electricity to the lamp. The lamp works with the ballast to project light into a light engine that separates the colors of the light, then recombines them with an image. The image is then reflected on the back of the TV and then onto the screen. So in other words more likely your lamp needs to be replace ,and you can find this lamps at http://www.purelandsupply.com/Samsung-DLP-TV-Lamp.html or ebay or http://www.discount-merchant.com/SearchResults.asp?Search=samsung%20lamps?click=52978 please keep us posted and good luck Samuel
Nov 13, 2009 | Samsung Televison & Video
No picture
check the video output its either on VGA or AV mode. check your settings. get your manual for that so it can help you a lot.
Apr 22, 2009 | Samsung - Projection TV replacement lamp...
No Power
Ballast is bad if you already replaced the lamp
Aug 10, 2008 | Samsung - Projection TV replacement lamp...
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
Henry  Thomas
Henry Thomas
