I have a Westcott iPoint evolution pencil sharpener. How do I open it to empty it.
  • 30 Answers
If you look at the top of the sharpener there is a small 1/4" cylinder , that will twist off, then the unti can be emptied. The hole clear part does not twist, just the "cap" on the top.
Please let me know if this helps, by rating the solution.
Thank you !
Posted on Mar 11, 2011
Tip
How to sharpen a pencil so the tip doesn't break
When I was in school it would always frustrate me that the tips of the pencil were always breaking in the sharpener. It took many tries of turning the pencil and turning the sharpener, different amounts of pressure and I finally found the secret.
Sharpening a pencil is a very easy thing to do. When you are using a hand sharpener, either a small plastic one with a cartridge to catch the shavings or the really small ones that don't catch the shaving, your put the utencile end of the pencil into the sharpener keeping it has straight as possible.
Applying a little pressure turn the pencil in the clockwise motion (you can turn either the pencil or the sharpener both will work). The shavings will begin to fall off and you keep turning until either you are satisfied with the sharpness of the tip or the shavings stop coming off. Make sure that you don't put more pressure on the pencil to make the shaving keep coming off because that will make the tip break and get stuck in the sharpener.
Pull the pencil out and clean the sharpener, it should be good to go. What I discovered was that if I had dropped a pencil a few times then the lead inside the pencil would be broken and this would cause the tip to break after sharpening. Treating your pencils nicely will keep them from breaking tips when you sharpen.
on Jan 30, 2014 | Office Equipment & Supplies
How do I open the prismacolor pencil sharpener
Unlatch the clear Top Cover to lift up like a Toilet seat lid which is hinged by a SUPER FLIMSY strip of plastic to the opposite side of the unit. This done with the Sharpening Holes facing UP.
Sep 28, 2014 | Sanford Corporation Prismacolor Premier...
How do I change the blade on a iPoint evolution pencil sharpener?
Have you tried unscrewing the small circle that you insert the pencil into? Once that part comes off the blade should be more exposed.
Jun 10, 2013 | iPoint 15509: Evolution Axis Pencil...
Ipoint sharpener not sharpenning
Computers don't come with pencil sharpeners.
May 20, 2013 | Computers & Internet
When I insert a pencil into my brand new school pro sharpener, the blades spin, but do not sharpen.
The website says to check and make sure its not jammed with pencil lead or something else. unplug it take the shavings bin out and flip it upside down so you can look into the sharpeners. Rotate them by hand till you can see the open side of the blade then use a unfolded paper clip and slide it in the path the pencil would usually take. This should knock anything loose the would be jammed in there. If it passes through to where you can see the point you should be clear. If you didn't dislodge anything or it still doesn't sharpen but the blades spin when you try to use the sharpener, then there is a tab that can get jammed back that needs to be in the foreword position. The tab is located where the tip of the pencil would point if it was actually being sharpened. if you run the paper clip through the machine (just like when trying to dislodge something) the tip of the clip will touch the tab. make sure its not jammed back (away from the opening/pencil) it should be as far forward as possible for the blades to engage. I hope this helps! This has been jammed many times by pencil shavings or gunk on my wife's (elementary school teacher) pencil sharpener.
Sep 22, 2011 | X-Acto XActo School Pro Electric Pencil...
The tip of a pencil is stuck in the bottom of my Westcott iPoint pencil sharpener. It won't sharpen pencils all the way now. Any way to get that out?
Use a small nail or pin to break up the piece that is stuck, then blow out the bits with a drinking straw, maybe one of the bendy ones.
Sep 09, 2011 | Vacuums
How do I open and empty the iPoint Evolution pencil sharpener to empty it?
It is easier to empty the iPoint Evolution pencil sharpener than you realize - place your hand on top of the clear lid and gently turn the very top until it lifts off. DO NOT try to separate the clear chamber from the base of the sharpener as this will prevent the sharpener from working (the exposed metal blades will stop working for safety reasons).
Oct 17, 2010 | Computers & Internet
Westcott ipoint evolution pencil sharpener manual to find out how to open it and empty the shavings?
You need to unscrew (counterclock) the thin top of the clear container, grasping ONLY the very top of it (5mm high), which is screwed to the top of the gray inner cylinder that contains the blades. This clear top IS NOT glued to the clear container!
Most people probabbly do as I did first, to grasp the whole clear container (because it seems to be a single part), but again, you need to turn ONLY the very top of the clear plastic (you can notice a fine line where the screwed top ends and the big container starts.
I hope you read this before breaking it up!
Good Luck!
Sep 03, 2010 | Office Equipment & Supplies
277 people viewed this question
jasbo
jasbo
