Question about Miele Touchtronic W3033 Front Load Washer
I washed the clothes then I close the door when empty, but I wanted to open again and it doesn't want to open... help.This a Touchtronic W3033. help!
Water leaking from bottom
water pump could be leaking or a hose. drain backed up
May 20, 2012 | Miele Touchtronic W3033 Front Load Washer
The door gasket is twisted, how do I fix it?
There is a metal retainer with a spring on the outside of the door around the seal remove that and re-form the seal around to door panel and secure with retaining spring. If this doesn't help you will have to replace the seal.
Feb 12, 2012 | Miele Touchtronic W3033 Front Load Washer
Why dose the water leak out from the Miele Touchtronic W1113 Large Capacity Washing Machine w/ Stainless Steel Honeycomb Washing Drum?
Hi dear.Please check the door gasket for any wear & tear.(Also open the door,ajar inside the door gasket, check inside of it for any fine tear or cut.)Please check for pump filter.Is it attached correctly.I hope that helps.Thanks.
Jun 19, 2010 | Miele Touchtronic W1113 Washing Machine
My miele w3033 has mold in the rubber gasket. wha...
hi,
you can purchase a cleaning product to run through the machine but white vinegar on a 95c wash also works.don't put any clothes in it though. if it has eaten into the door seal too much you can easily have them replaced. always leave the door open after each wash for about half an hour to let it dry out otherwise a damp environment is perfect for bacteria to develop. lots of hot washes and the door open prevents this.
May 19, 2010 | Miele W2240 Front Load Washer
Water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
Dec 15, 2009 | Miele Touchtronic W3033 Front Load Washer
Washing machine stinks
do the clothes stink too? or just the washer? if you have a crawl space check the washer drain it could be draining under the house...and vapors coming up through line......
Nov 08, 2009 | Kenmore Elite HE4 Electric Dryer
There is a moldy smell....I have ran a load with no clothes and just bleach and it smelled ok for a week and now smells again
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub/basket, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 24, 2009 | GE WSXH208A Front Load Washer
My Miele Touchtronic W1119 shows the error message Drain/Intake Fault. The intake and filters are fine. What's going on?There is no water standing in the drum. How can I reset this?
Hello Buvamo,
You may want to check the water valve and make sure it is all the way up where the intake line is.
The other area to check for water not draining is the lint trap. While the intake/drain fault is on the door will not open for the lint trap.
There is a release lever at the bottom of the machine (Orange in color) that is below and behind the trap door. Just pull down on the lever and that will open the trap door. You may want to put a towel under there as it will leak once the door is opened. inspect and clean the trap and try running cycle again
Sep 13, 2009 | Miele Touchtronic W1119 Large Capacity...
Drsining washer manually
open the little door at the bottom fron and twist open the lint filter clean out
Jul 12, 2008 | Miele Touchtronic W1113 Washing Machine
Miele Touchtronic W3033 Front Load Washer Logo
26 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
