Question about X2Gen MG15VT 15" LCD Monitor
X2gen 17" Monitor
Hi
My X2gen 17" Monitor is turned landscape. Not only the taskbar but the entire desktop. The taskbar is to my right and the desktop is in the same position to my left. the screen is full right out
Thanks
Rohan
ctcidexpress@yahoo.com
YSE
Posted on Nov 13, 2008
Lost power cord. What specs. i have output 9vac 1000mA. Is this ok
No, it's way too low power. Most probably you need 12V and something like 4-5A (4000-5000mA). The higher the current rating (Amps) the better, some reserve is always good to have; the unit will draw as much current as it needs, the rating means the maximum current that the power supply can deliver.
Good luck, and please come back with a rating/testimonial if helped :)
Jul 13, 2010 | X2Gen MG17J 17" Monitor
My X-2gen monitor turns white upon startup.
You may have failed T-CON board (part of the LCD panel), bad connection on the ribbon cable between the LCD panel and the logic board, no 5vdc feeding the T-CON board. Need to do soem checking.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jul 04, 2010 | X2Gen MG17J 17" Monitor
How do I turn on monitor speakers
Hi Anonymous,
Typically, the speakers need to be plugged into the green audio port on the back of your computer, or use HDMI cable, if your system can use one.
May 20, 2010 | X2Gen MG17J 17" Monitor
Backlight don't work
Try these guys http://www.lcdparts.net/CCFL13D.aspx
Can't specifically see the MV17F, but I am sure that M$ OEM it from another company. You may need to contact them to get the right replacement part number
Hope it helps, if so please leave feedback, if not - let me know and I'll try and help more!
Jan 24, 2010 | Microsoft X2Gen MV17F / 17-Inch / 1280 x...
Display orientation issue
Right click the mouse on an open area of the desktop, In XP select properties; Vista it's personalize. Go to the display settings and make sure it is set to portrait. Hope this helps.
Jul 02, 2009 | Sony SDM-HS73P 17" LCD Monitor
Icons and everything displayed sideways
If you're referring to the taskbar that's usually on the bottom of the desktop, click on the taskbar and drag it to the bottom. Then right click on the taskbar and check "Lock the taskbar". This should solve your problem. All the best.
Greg
Jun 23, 2009 | NEC MultiSync 77F 17 in.CRT Conventional...
Dell Flat Screen monitor
There are hotkeys for the graphic display ctrl alt arrow key right turns normal, 90 180 270
Sep 22, 2008 | Dell Computers & Internet
Display area extends beyond the area of the monitor
Hopefully there is a cable loose or something like that. Try reseating the cabling. I think it is a monitor problem but it wouldn't hurt to try the monitor on anouther computer. It sounds lke a heat problem in the monitor scanning circuitry. It may be repairable if the picture is still looking good. Youll need a schenmatic and some patience and a soldering iron or a reputable service tech.
Sep 20, 2008 | X2Gen MG19MY 19" LCD Monitor
X2gen monitor
Hey I've read about your problem cus I had same thing weird lines flying on the screen from one to the other side or crossed and I've found the solution ,there is not enough power strength coming to the monitor power supply because you have to many thong plugged to the same splitter ,just unplug the monitor power supply from this splitter and connect it to another power outlet ,not the same ,another and it should fix the problem at least it fixed my so good luck ,and sorry for my spelling cus I'm Polish ,but I'm trying!
Jan 24, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG15VT 15" LCD Monitor Logo
94 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
