Question about Toshiba Satellite A45-S250 Notebook
Toshiba Satellite A45-S250 PC - where is the ram located?
Hi there
I bought 2 gigs of ram to replace the standard. I remove dthe battery and screws buyt could not locate the ram anywhere under the laptop?
    Genius:
  • 2,028 Answers
The memory is under the keyboard on these models. Remove the plastic piece with the power button, and you will see the screws for the keyboard. Don't forget to rate me (fixya). thanks
Posted on Jul 31, 2008
I have linksys wireless g router (WRT54G2) and wpa is enable however, the Toshiba A45=S250 can not connect to the linksys wireless any idea?
Posted on Sep 10, 2008
How do I access the RAM for upgrading?
make sure it is unplugged and powered off and battery removed before removing screws.
the screws are small so you will need a small screwdriver Usually Phillips head
There may or may not be a memory module in there already. Make sure to research proper memory size - speed and brand before upgrading.
You will be removing the keyboard and other components make sure to note where they go and dont pull too hard
Here is the manual and go to page 67
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=555703&rpn=PSA40U&modelFilter=A45-S250&selCategory=3&selFamily=1073768663
Hope this helps
Mar 16, 2010 | Toshiba Satellite A45-S250 Notebook
Toshiba A45-S250 laptop keeps trying to load XP but keeps rebooting. I would like to use my recovery disk but I don't know how to get the laptop to recognize or boot from the disk. Safe Mode won't load...
Sorry mate...
It seems the the issue is with RAM.
A complete Hardware malfunction/ failure issue.
All you can do it is to replace the RAM that you have in ur laptop.
It will work for sure.
Best of luck.
Mar 02, 2010 | Toshiba Satellite A45-S250 Notebook
Where is the ram?
Removing the keyboard exposes the two memory slots, which are covered by a plastic sheet.
You can download the owners manual here which gives directions to remove and replace your ram. (Starts at page 70) Click here:
http://www.retrevo.com/support/Toshiba-A45-S1202-Laptops-manual/id/614ci359/t/2/
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 02, 2010 | Toshiba Satellite A45-S1202 Notebook
How to replace the dvd drive in a toshiba Satellite A45-S250
Most toshibas have a small screw on the bottom of the computer, next to the memory cover. take screw out and the use a paper clip or turn on laptop, to eject dvd drive, then turn off laptop, unplug power, then pull on drive outward, shold slid out of laptop,.
if replacing with new drive remove metal screw clip off the back of old dvd drive and screw onto new dvd drive, slide in and replace screw!
Jan 13, 2010 | Toshiba Satellite A45-S250 Notebook
HOW TO GET TO THE RAM IN A45-S250
You will find the memory on the Toshiba A45-S250 under the keyboard. Snap of the grill that also has the on/off button on it, just above the keyboard. You will find two screws holding down the keyboard and another screw near the middle holding down a small silver piece that is holding down the center part of the keyboard. Lift the keyboard from the screen end toward you. Memory is located under a clear plastic flap.The power should be off and the battery removed during this operation. Be sure to touch some metal piece to ground yourself also. Good luck.
Jan 06, 2010 | Toshiba Satellite A45-S250 Notebook
The right hinge on my screen is broken. Can it be
Here's a link to hinge repair procedures...
http://www.laptopka.com/2007/08/01/replacing-satellite-a45-broken-hinges/
It also has a link to search for the replacement part you may need.
Jan 01, 2010 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite A45-S130 boot failure
* If it's a BIOS problem, try this :
1. Shutdown ur system, and remove the BIOS battery.
2. Reinstall it and start again.
3. You can also replace the battery. (if above steps don't works!)
4. Try to get a updated version of BIOS driver. (if above steps don't works!)
* If u r also hearing any kind of beep sounds, it may be bad RAM (memory). Try this :
1. Shutdown ur system, and remove the RAM.
tell me if these steps don't work! :)
Dec 31, 2009 | Toshiba Satellite A45-S250 Notebook
How do i add more ram
The Toshiba Satellite A45-S150 has 2 bank(s) which have 1 socket(s) in each bank for a total of 2 memory socket(s). This means the Satellite A45-S150 can support up to 2 individual RAM modules. Look on bottom of laptop and there will be place to take screw out and you will see the 2 modulars. Below is a visual representation of the memory bank(s) and socket(s) configuration for the Toshiba Satellite A45-S150.
Nov 28, 2009 | Toshiba Satellite A45-S150 Notebook
Toshiba Satellite A45-S250 Notebook Logo
270 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
