Question about ASUS P4XP-X Motherboard
Heatsink fan spins without pushing power on button, no display asus p4xp-x, reseat video adapter, ram, remove connector power and signal to optical disk only mouse keyboard ram and video adaptr
  • ASUS Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help don
Posted on Mar 11, 2011
When i press power buttton computer will on and suddenly turned off i try the same thing second time power is on but no display
I see your concern is that your computer will not power ON but if it does it does not show anything at all on the screen.
Reseat the RAM on you motherboard also clean the heatsink and FAN of teh processor and at the same time reseat the Processor as well.
If the issue is still the same and you do not see anything on the screen, if you have a video card remove it then try using the built in Video on the motherboard if it show video on the screen using the built in video card then the issue will be the Expansion video card you have.
Aug 05, 2011 | ASUS P4P800 Deluxe Motherboard
No ram beep comes without ram and no display
> No RAM beep comes without RAM.
That is to be expected -- when the motherboard does _NOT_ detect any properly-mounted RAM, the motherboard sounds the "no-RAM" beep.
> and no display
Correct. Without RAM, the computer cannot "paint" anything onto the video screen.
Nov 06, 2010 | Intel D845GVSR Motherboard
Toshiba Satellite 1005-S157 shuts down periodically by itself. Replaced fan/heatsink. Still shuts off.
you need to check a few things... when the fan/heatsink assembly were replaced, did you make sure that the thermal pads on the CPU and GPU are NEW/Good.... Make sure that the Heatsink GPU pad Firmly sits in the chip....
You can test the thermal controller by using a hair dryer or heat gun.... Point it onto the heatsink pipes and see if your fan spins when the pipes get hot, then remove and see if the fans slow after a minute...
You might have faulty RAM or Misseated RAM... Pull The RAM chips and reseat them...
Also Make Sure Your CPU Is Locked Down....
Periodic Shut Downs Can Be Caused By Quite A Few Different Things...
Typically it's due to Thermal Damage
Though Failing RAM or A Failing Hard Drive, Overheated Video/GPU Chip, Or Even Failing CPU can as Well Cause This Issue...
Nov 16, 2009 | Toshiba Satellite 1005-S157 Notebook
HP DV6000 Notebook - Dead/No Post
All I know is wife's did the same and they replaced the board, not repaired it.Hers was out of warranty and they fixed it free
Feb 10, 2009 | HP Pavilion dv6119us Notebook
Hi... When I push the power button on my HP Desktop, just the amber light in the button comes on....nothing else. No noises (hard drive spinning-up, fan, etc)...nothing.
The amber light is signifying an error. Most common are the power supply, video card, or RAM. Worst case is motherboard has went bad. Try reseating the RAM without installing the video card, if it boots then it's the video card. Replace the bad part & you should be up & running again. Hope this helps & please remember to rate my answer. Thanks.
Jan 02, 2009 | E-Machines eMachines Desktop PC
ASUS NCT-d
Hi, have you tried removing the CPU and using a Air Jet Spray can to clean all contact pins and pin holes? The problem sounds like a loose chip. So also check all on board chips are seated, including RAM chips. Air spray can be bought from most Computer stores. Goodluck mistyman
Sep 09, 2007 | ASUS NCT-D (90MSV430G0UAY) Motherboard
ASUS P4XP-X Motherboard Logo
46 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
