Question about Carrier XHC101D Air Conditioner
My air conditioner is having a problem..when i turn it on it will get cooler for five seconds then after which the cooling machine will shut down but the blower is still running...can u please help me with my problem...thanks
  • 3 Answers
For how many months have you using your unit.
Posted on Mar 11, 2011
Air conditioner turns on, then off, then on again immediately after
going out on safety or relay getting erratic connection from t-stat.
Nov 07, 2013 | Dometic Rooftop RV Air Conditioner
My pacr10 blows air but compressor wont kick on
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 13, 2017 | Windchaser PACR10 Portable Air Conditioner
I want to make the air cond. get cooler. I want to cool fruit in this room. Can it be done. Maybe override the therm.?
To cool fruit ect you need something much more than a window unit air conditioner, they just don't have the cooling capacity to do that job. You need a walk in cooler to cool food down.
Jun 19, 2011 | Maytag M6Q10F2A Air Conditioner
It starts running and after about 15 seconds it shuts down with a message of service then what i see as an alarm 7 and shuts down
If it is a evaporative cooler that is breezair, coolair or braemar it will be because it has to low or too high a voltage supply. another problem could be the capacitor is the wrong size
Feb 09, 2011 | Mastercool 67680 Evaporative Cooler Air...
My lg 15000 er air conditioner is blowing hot air i could hear compressor starting for five minutez of cooling the n shuts off and hot air again i have cleen filtered and cleaned coils inside part
The unit is probably low on freon and so it is running too cold....this trips the freeze stat and shuts down the compressor till it warms up and you reset it by turning it off and then on again...
The unit will need to be recharge or replaced...
Here isa tip that I wrote about how to add refrigerant to a air conditioner or coolingsystem
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Sep 27, 2010 | LG BG8000ER Air Conditioner
Air conditioner will cool for five minutes and then turn off. comes on and off sporatically but never stays on for more than five minutes.
could be the pressure cut off switch is working out in advance as it cut off. If there is enough cooling then it can be possible that the filter is clogged and the condenser is clogged. If by choosing a higer fan speed for blowing iff the ac goes on for more time, then clean up all the fins and filters to make it more efficient to heat exchange, if not change the thermostat/ pressure cut off switch.
Sep 25, 2010 | Heating & Cooling
Vulcan bonair evaperative cooling unit will not operaate when switched on
If shut down at end of season by air con person may be switched off in roof unit. just remove one side and should have switch in unit usually near pump
Nov 01, 2009 | Mastercool 67471 Evaporative Cooler Air...
HOT AIR BLOWING INSIDE THE HOUSE
I know there are not that many sites--very few--that cover the informational guidance on the maintenance and technical difficulties of evaporative coolers, and so I feel compelled to share with you this very good, but rare, handyman site that does:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers.htm
As you'll see, the link above has a section dedicated to evaporative coolers.
As to your specific problem of your cooler's blowing hot air, yes, the humidity is listed as one of six (6) possible causes of this cooler problem. To find out whether the other five causes are applicable to your situation, here is the direct link to the diagnostic article on hot-blowing coolers:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers_Cooler_Does_Not_Blow_Cool_Air.htm
You should be able to review this article, and, one by one, determine what causes listed therein are not affecting your cooler in order to ultimately end up with one remaining listed cause that is the likeliest cause of your cooler's failure to blow cool air into your house.
This should help.
Brad
Jul 08, 2009 | Mastercool 67680 Evaporative Cooler Air...
Air conditioner is not cooling. The fan is running. When I turn the thermostat past 7, the unit shuts down. Any ideas? Low on Freon?
Sounds like a leak to me - if you have a set of guages available (know anyone working in the refrigeration field???) you could tell this for certain.  Otherwise, try running it when it cools down outside and see what happens.  Take a stick thermometer, and put it in between the fins on the INSIDE condenser coil.  If they get cooler, but not down to about 50 degrees, then you are low on refrigerant.
Good Luck!
May 26, 2009 | Heating & Cooling
A/c shuts down after about 30 seconds
Sounds to me either a low refrigerant charge or low air volume over the evap coil (inside). There is a sencer for temps outside maybe it's tripping out on that.
Nov 10, 2008 | Mitsubishi MS17TN Air Conditioner
Carrier XHC101D Air Conditioner Logo
27 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
