Question about Del Mar Pacific Fitness Precor S321 Fitness Wall Chart
The cable on my precor s3.21 was cut by vandals and i need to know how to route the new one
ER 05 displayed on precor 9.31?
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Nov 23, 2013 | Precor Exercise & Fitness
Upper PCA problem
Please RUN the software calibration for eady diagnostic and fix it. God bless you
However follow this steps and fix it. God bless you
Probable Cause 1. A failure in the upper PCA overloads the low voltage power supply and causes it to drop below the preset level.
2. A fault in the interconnect cable (upper PCA to lower PCA) causing the input voltage to the upper PCA to be too low. Corrective Action
  1. If the error message is continually displayed when the unit is powered up, the upper PCA needs replaced.
    External causes may make the error appear intermittently.
    1. If the AC input of the unit dips significantly during power up test sequences, the test could fail causing the error to appear.
    2. A treadmill connected to a non-dedicated AC circuit can experience this error intermittently.
  2. Determine if the interconnect cable is the cause by substituting a know good cable in place of the current cable. For test purposes, the substitute cable needs to be connected directly between the upper and lower PCA's, without routing the cable internally.
Nov 22, 2013 | Precor 9.27 Treadmill
Precor error 12
Precor Error 12, Watchdog (Lower PCA) Probable Cause 1. A failure in the lower PCA overloads the low voltage power supply and causes it to drop below the preset level.
2. A fault in the interconnect cable (upper PCA to lower PCA) causing the low voltage power supply of the lower PCA to be too low.
3. A failure in the upper PCA that overloads the lower PCA low voltage power supply causing it to be too low.
Corrective Action
  3. Determine if the upper PCA is the cause by substituting a know good upper PCA for the existing upper PCA.
Precor Error Code 12 12 Watchdog Lower PCA
May 04, 2013 | Precor EFX 546i Elliptical Version 4
Parts for a PreCor 9.1 treadmill
go www. precor.com or www. fitnessrepairparts.com or www. treadmillspartszone.com
God bless your
Jul 06, 2012 | Precor 9.1 Mode 1 Treadmill Repair Parts...
Vandalized equipment
Depends on what all they cut. You can turn the engine over by applying direct power to the starter, but without knowing what type of vehicle and what all they cut will depend on if it'll start and drive.
Jan 17, 2012 | Cars & Trucks
Error 12 appears on display? What do I do?
Corrective Action
Jul 12, 2011 | Precor EFX 546i Elliptical Version 4
I need assistance with reassemly of my del mar home gym. I forget how to run the cables the model is the s3.21
There are three exploded diagrams for the Precor S3.21 at this link. It says it is for the A997 version so I don't know if that is the exact thing for you or not, but maybe it will be helpful.
Apr 05, 2011 | Del Mar Pacific Fitness Precor S321...
Error 30
error 30 is no power to upper PCA or upper console. I believe in the 546 there are 2 interconnect cables, one lower that runs from the back to the bottom of the mast, and an upper, that runs from the console, down the mast. They meet at the front and connect using what's known as a mid-point connector (technical, I know). Unfortunately, there's no real test available, aside from checking the 3 connections other than substituting out for a known good cable. You can remove the console and ensure that the cable wasn't plugged into the CSAFE port on the console board. Sometimes, if a machine has been transported or moved, this can happen as the CSAFE and LOWER PCA ports are identical, but it's printed on the actual circuit board under it. Now depending on the serial number sequence of the machine, the cable can route a few different ways, although most use a 2 interconnect cable system with a mid-point connector (little black female/female connector) I would be able to get a little more detailed if I had a serial number, the first 4 digits are enough to establish the particulars about a machine.
May 27, 2010 | Precor EFX 546i Elliptical Version 4
I need the belt diagram for a 2005 Dodge 5.9 diesel
Look up.See the hood Serpentine routing sticker? There you go, unless of course the hood has been replaced or vandalized
Nov 01, 2009 | 1995 Plymouth Voyager
Power windows on 2000 Explorer
Yes, They are all tied Together into 1 Wiring Bundle.
Jan 17, 2009 | 2000 Ford Explorer
Del Mar Pacific Fitness  Precor S321 Fitness Wall Chart Logo
257 people viewed this question
Top Del Mar Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Del Mar Exercise and Fitnes Expert? Answer questions, earn points and help others
