Question about HP Vs17 17" LCD Flat Panel Monitor
I have a HP vs17e monitor and for last 2 days it will only stay on for about 3 seconds then go black the blue power light is one and no blinking. any ideas what is going on?
  • 11,361 Answers
It can be the power supply, backlight inverter circuits, bad lamp assemblies.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 11, 2011
I recently bought a Hp Lcd w1907 Monitor off craigslist, the screen worked fine for about an hour then went black, button stays blue. Now every time I power on the monitor it stays lit for 3 seconds...
hi the cause is screen back light not working properly. you need to remove the back cover of the monitor to access the internal part of the monitor. then look for the connector of the cold cathode fluorescent tube back light going to the power inverter board of the back light you will noticed a dry joints which cause a loose connection that is why you hear a sound that cause of spark. you need to re soldered the connector or replaced if totally burned.
Nov 08, 2012 | HP w1907 LCD Monitor
Why is my HP vs17e monitor blue power light blinking?
the blinking of power led means that the power supply is not working fine, this can be caused by:
  1. a puffed capacitors in the secondery side of the power suplly
  2. a shorted transistor in the inverter section
  3. a damadged flyback transformer in the inverter section
to solve the problem, unplug the LCD from the power source, wait for 30 mn to discharge the main filter capacitor (150 uf, 400 V), look at the capacitors, if they looks good, check the transitors, if you find a shorted one (0 ohm read) change it. don't forget to test the continuity of the flyback transformer (primery and secondery). i hope that this will help you to solve the problem.
Dec 12, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
HP vs19 monitor does not turn on.
You may have to inspect the inside of the monitor. You may have to dry it out from the inside and look for burned component which may be caused by a short due to the moisture.
Aug 15, 2009 | HP vs19 (Silver) 19" LCD Monitor
Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Aug 14, 2009 | Samsung SyncMaster 920NW Monitor
My screen stays black but my pc is on
it sounds like your mointer is ****, i highly doubt the game caused it. try another mointer, or sell that one on ebay and buy a new one
Jun 14, 2009 | HP Computers & Internet
Hp vs 19 lcd monitor and it randomly just turns off and then flashes back on for 2-3 seconds then goes back off again
phantasighz, Did you swap out the monitor to get online? Or has the HP LCD mysteriously start working fine again? We need a littile more history here???? Once the LCD goes to BLACK, will it stay black, or will it all by it's self try to start up again, and then repeat the whole cycle again forever? Did you buy it new? How old is it? Have you talked to HP to see if they have swapout program? You send them your's+$40 to $90, and they send you same model refurbished(new CCFtubes/inverter/smps) installed. If you don't know by now, you are dealing with a lighting problem. Do you have any of the new energy saving curlie-Q screw-in compact-fluorescent light bulbs? Their high voltage source is derived alittle different than the way your monitor does it, and of course the Cold Cathode Fluorescent tubes are thinner and straight and hung horizontally on the opposite side of the LCD/FPD you look at. All you need to do to learn more about your problem and what hundreds of others are doing to repair their LCDs is GOOGLE search this: bad caps in lcd monitors. Hope this info helps you understand the technology better. I'm louie12fix on fixya or lmistyrel @aol.com
Apr 14, 2009 | HP vs19 19" LCD Monitor
Monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Aug 27, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
307 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
