SOURCE: how do i open my cleaner to put a belt on
Thank you for your fast reply, I took off the screws on the lid and replaced the belt with no problem
SOURCE: Vaccum cleaner belt change
If you've put a new belt on and you still are getting a rubber smell, then odds are that your agitator (the rotating brush) is not turning freely, and that means either (a) you need to remove the end caps and remove any hair / debris that is under those end caps, or (2) the bearing(s) of the agitator are bad. Depending on the model of the Sharp (which was not provided), you may be able to order just the defective bearings and replace them (or take the agitator to a vacuum shop to have them do it), or you can (or may need to) order the agitator assembly complete.
SOURCE: I need a belt size for the Fantom F 12052 00 model
Here is the belt you need and the manual with instructions:
http://vacbelts.com/fantom-fury-belt.htm
SOURCE: A BELT FOR THE VACCUM CLEANER (EUREKA)
Here's a link to this exact belt for your vacuum cleaner on our website:
http://www.govacuum.com/1555.html
I hope this information helped you! Please be sure to rate this helpful if it did so other Fixya users with this vacuum can easily find this belt.
Thanks,
Chris J.
GoVacuum.com
SOURCE: I have a Fantom Thunder Vacuum. Missed placed my
depending on your model, and I am going from memory on this one. I have not seen this model in a while.
1 headlight on the unit:
there are 2 screws on the back of the cover for the brush. Just above the wheels. Remove those two screws and the cover will come off.
2 headlights on the unit:
use a small screwdriver to remove the headlight lens covers, remove both of the light bulbs, and then the two screws are under the lights. there MAY be 2 more screws again at the back of the unit above the 2 rear wheels to remove as well. again the cover should come off and you will have full access to the belt/brush under there.
