Question about Dishwashers
After i use machine it is still dirty - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Posted on Mar 11, 2011
My cappucinatore no longer draws the milk into it. Secondly, the machine leaks dirty water.
You have to use protein dissolving cleaners on all machines that draw milk. We use a product called Rinza in our commercial machines x 6 :>)
It could also be the pump.
Dirty water, especially with grounds in it is caused by faulty seals.
It is time your machine was professionally serviced.
Dec 02, 2016 | Coffee Makers & Espresso Machines
Dirty copy result even if i replace a new drum
There are small wires that charge the drum to transfer image. Not sure if they are in drum unit or not on this machine. If the transfer chargers are dirty they will cause a dirty or voided copy. Make sure document glass is clean. Unplug machine check for these small wires if dirty gently clean with cotton swab or soft towel. Hope this helps
Mar 02, 2014 | Kyocera FS-1135MFP Copier require feeder
Why is my ice dirty
There are two ways to get dirty ice - dirty water or a dirty machine.
If the water that the machine is processing is dirty, you'll get dirty ice. Check that your water filter is working properly, and that the filter core is in good condition. If the water supply to your machine is really dirty, consider a double filter.
Also, check inside your machine for deposits of silt, minerals or other undesirable materials. Clean out the inside of the machine thoroughly, but don't use any household cleaning products or acids - they will damage your machine or leave an undesirable perfume which will contaminate the ice - Just use water. Also don't use anything abrasive on the internal surfaces. If there are mineral deposits, you can dissolve them with household vinegar by soaking them or spraying them continuously, and then rubbing with a non-abrasive sponge. There are also commercial solvents especially for icemakers. Rinse the machine thoroughly to remove any odours, and throw away the first harvest of ice.
Nov 05, 2013 | Kitchen Appliances - Others
Dirty thread
hi there,can you check please that area around lower needle bar bushing? maybe some oil drop from this area.- check the adjustment screw for lubricate hook from down maybe need to decrease the amount of oil how lubricate the hook by turning to minus direction.best regards
Dec 18, 2011 | Juki HZL-E80 Computerized Sewing Machine
All cycles work except harvest manitowac ice machine
Ice thickness probe on Manitowoc and float switch may be dirty or stuck if hoshi. Manitowoc sometime the thickness probe can get dirty and a film of algae and not sense ice properly but rare
Oct 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have never used a shampooer before when I use it it says to empty out dirty water. I don't have any left. My tank is empty. Am I doing something wrong.
Suggest that you do the following.
Remove the TOP ("Clean water") tank. Fill it 1/2 full of water. Put the top on the clean water tank and place it back on the machine.
Release the machine handle and remove the cover of the "dirty" water tank. Inspect the back of the tank to be sure that the vacuum adapter in located in the rear of the dirty water tank. If not-that is your problem. If yes, restore the top to the dirty water tank.
Power the machine on.
On a kitchen floor, power the machine on. Pull the trigger and hold it for about 30 seconds. You should see water gathering around the brushes. If not, that is a problem.
With water around the brushes, release and lower the handle and and move the machine over the water. It should vacuum the water into the dirty water tank.
Is all of that happening?
Nov 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
When i send a fax they are really faint when recieved
This is an indication that the scanner or "optics" of you fax is dirty. It's just the opposite of what you would think...on many fax machines, dirty optics produce a light image on the reception machine.
Nov 17, 2009 | Office Equipment & Supplies
Beeps 3 times when turned on
3 beeps means the machine has ran two 1 hour cycles back to back to make ice an average timeframe for ice making is 25-30 min. Could be several issues, float switch dirty, water valve leaking by, dirty spray tubes, dirty evap., then go to refrigeration Expansion valve, compressor, charge, Hot gas valve leaking by,,,,,
Jun 23, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Hotpoint machine is not throwing the dirty water out
blocked drain piping or blocked impeller on drain pump or failed coil?complete pump,that would be the area that should be looked at to solve problem
May 05, 2009 | Hotpoint Washing Machines
Dishwashers Logo
145 people viewed this question
Top Dishwashers Experts
Owen Barnes
