Question about Eljer 141-0220-00 Toilet Tank White
My Eljer 141-0220 tank cracked. The bowl is fine. Can I replace the tank with a different brand or style? Seems this tank is hard to find locally.
You can find tank on amazon. take a look here Amazon com Eljer tank enjoy
Posted on Nov 25, 2014
    Genius:
  • 1,739 Answers
I would first try to purchase a replacement tank for your product. Visit your nearest Eljer dealer with your product number and find out if the tank is available as a single piece.
You can locate your nearest dealer using the on-line search function:
http://www.eljer.com/dealers.aspx
Alternatively you can Eljer directly: 800-442-1902, Monday through Saturday, 8:00 A.M. to 6:00 P.M. EST.
Your toilet is still listed as available on the website so obtaining a replacement should be possible. Trying to match a different tank and ending up with a leak would create more problems that anyone would want.
Posted on Mar 11, 2011
Testimonial: "Thank you very much! You answered all my questions and I know what to do now."
Where do I find a part number on an Eljer toilet tank?
You can purchass a whole new fixture for the same cost as just the tank I believe...
any eljer tank will fit your toilet bowl... they are pretty universal.
Does the current tank have a crack or something?you can replace the seals easilly enough if the tank is just leaking at the seal ... and the flush mechanism is also easy to replace , should that be the reson to swap out tanks too.
Mar 24, 2013 | Eljer 141-0220-00 Toilet Tank White
Eljer 0220 toilet leaks from tank to bowl, then fill valve spurts out water from top and around the edges, and also through the tube that goes to the overflow. Replaced the flapper, but still leaks. Also...
When the tank is full and leaking into the bowl reach in and put slight pressure on the flapper and if the leak stops then you may have the wrong flapper or the flapper is not installed properly. If that is not the case then make sure the flush valve seat is not cracked or that the surface is not warped.
Mar 05, 2011 | Eljer 091-0220-00 White Savoy Two-Piece...
25 year old toilet, all of a sudden, seems to be shifting and the tank is now angled and one side is touching the wall, nothing seems loose, or wobbly, but it must be moving, since it never was this way...
The tank to bowl bolts need to be replaced. The tank will need to be removed and new SOLID BRASS BOLTS and the gasket will need to be replaced. When you tighten the new bolts on the
tank, lay a two foot level across the tank with cover removed. Tighten each side a little at a time.
I always tighten the tank down until it just touches the raised rib on the bowl, and no more than that.
You can buy generic tank to bowl kits, but make sure the bolts are solid brass.
Nov 05, 2010 | Eljer & Patriot& Elongated Toilet Bowl
Have a eljer century toilet that is 1 yr old that constantly has a small amount of water that runs down the bowl from under the rim. We have replaced all the parts in the tank but it still leaks. What...
There is no easy answer for your problem other than the flapper is not holding the water in the tank It is the only thing that keeps the water from going into the bowl when a toilet is not in use...on ANY toilet. Not all flappers are of the same quality, so be sure to replace it with the EXACT style as came with the toilet.
Oct 23, 2010 | Eljer Home
Low water level in bowl after flushing
The small black tube that goes into the overflow is used to fill the bowl after flushing. Would check to make sure that water is coming out of that tube at full force or if its coming out at all.
May 11, 2010 | Eljer & Elongated Toilet Bowl
I have 40 year old eljer toilets seat cracked,
This website appears to have what you need
http://www.plumbingsupply.com/eljertoiletparts-patriot.html
Hope this helps?
Jan 20, 2010 | Eljer & Patriot& Elongated Toilet Bowl
No back flush pressure
increase the tank water level half inch at a time till you have the back flush pressure.
seems like the water in the bowl is too low to create any wirlpool.
Oct 30, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Eljer 141-0220-00 Toilet Tank White Logo
4,561 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
