Question about Acer eMachines 520-2890 Notebook
My e525 laptop starts up, and after the big "e" logo the screen goes blank.* Whenever I press a key there's a loud beep. How do I fix this? *As far as I can tell the screen is blank, but it's hard to see anything since the screen light quit working a few months ago, which is another problem I've been unable to fix.
  • 135 Answers
Try this... 1. Remove the battery 2. Remove the memory for about 5 minutes 3. Re-insert the memory 4. Press ESC for about 3 minutes while putting the power adapter. 5. Then turn on without battery.
Posted on Mar 11, 2011
My emachine E525 goes white after logon
First try to start pc in safe mode,by normally Pressing F8 key when windows starts up
If you have done then update your graphic drivers just go the site of your Laptop manufacture. Once there enter the model number OR service tag of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop
-Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
If -If this didn't help you then simply get the Intel software partner Reginout to fix all the errors and registry issues which causing blue screen
Jun 18, 2013 | Acer Computers & Internet
Mercury mother bord not loding satup manu with all f key and 'del' stop in start screen
1) Look at the bottom of the Mercury logo screen when it comes up.
2) Memorize or write down the -> enter BIOS Setup, or enter CMOS Setup key.
3) Restart the computer.
Let it go to Windows, then Start > Turn Off Computer > Restart.
Won't go to Windows? Hold down the CTRL and ALT and DELete keys AT THE SAME TIME. This will restart your computer.
AS SOON AS the monitor screen goes blank, (Windows is restarting), tap on the enter BIOS Setup key repeatedly.
Tap in 2 second intervals.
Hear a series of beeps? They are Stuck Key Error Code beeps, and you are causing them. Ignore the beeps.
Computer is off?
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup (CMOS Setup) key.
The enter BIOS Setup window goes by F-A-S-T. The above method/s will get you into BIOS Setup.
Regards, joecoolvette
Nov 05, 2012 | Computers & Internet
Whenever I try to start my Toshiba Satellite Laptop the Toshiba logo comes on but then the screen goes blank and all there is is a blinking underscore in the upper corner of the screen; I already set
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Jul 15, 2012 | Toshiba Satellite Computers & Internet
All funcions freeze.have to switch off and start again .crash's screen goes blank' it is only four monts old
Try to start the compute in safe mode, and check if the computer works without any issue, to access safemode, you have to press the F8 key while you get the Acer Logo.
Try restoring the Operating system by pressing Alt+F10 when you get the Acer logo and follow the screen.
Apr 07, 2010 | Acer Aspire One PC Notebook
Aspire 5315: Loud, Long, High Pitch Beep During Start Up
you need to replace the memory..or try to make clean using a Paper Eraser for make a clean the memory..clean the all pin connectors..good luck
Jun 13, 2009 | Acer Aspire 5315 Notebook
Finding info on how to change Compaq 6720s bios logo
just tell bios to blank the screen on start up then go into windows and see if in the display section you can stop the compag logo from going on, and also have a blank screen for your screen saver.
Mar 21, 2009 | HP Compaq 6720s PC Notebook
White blank screen
i think it is a some kind of virus in ur system try going in safe mode and let me know if still problem is there otherwise u have to reset ur OS to get rid of that and do protect ur system with good internet security like pc cillin or norton
restore OS simple procedure pls backup ur data first
When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
if there is a window showing in the taskbar blank
Mar 05, 2009 | Acer Aspire 4720 Notebook
Acer Aspire 5100 will not start right
It seems your hard drive has corupted.
This sucks, all you have to do is push ALT F10 and then go through the reseting menu, you will loose everything on there though except the original data.
Jun 24, 2008 | Acer Aspire 5100-5033 Notebook
Acer eMachines 520-2890 Notebook Logo
450 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
