Question about Coleman Heating & Cooling
Out thermosat for our furnace and air conditioners will not work. There is no poweer going tot he thermostat at all.
    President:
  • 1,515 Answers
Hi, if you have no power to the stat, go to the furnace if this is a split system. Depending on the year you have, this unit may have the main circuit board with a 3 to 5 amp control fuse plugged into it. If this is what you have, check this fuse, it is the same as the fuses in your car. If you don't have this circuit board, locate the transformer where your thermostat wires come in and check for power at both the 120 volt primary side ( power in ) and see if you have 24 volts coming out of the secondary side of it. If no power in, check the circuit breaker to the furnace. If there is power in and nothing out, the transformer is gone. Check close for any breaks in the stat wires at the furnace also. I may need to have the model and serial numbers, and if its a split gas fired or a heat-pump unit if this information does not apply to your unit. Let me know.
Shastalaker7
A/C, & Heating Contractor.
Posted on Mar 11, 2011
I replaced the control box and thermostat but i have no power to the thermostat
I know this is an old question but almost all rooftop AC units get thermostat power from the Furnace. If you don't have good 12 volts at the furnace your thermostat will not work.
Jul 12, 2014 | Dometic Rooftop RV Air Conditioner
Furnace is not working after changing thermostat
the thermostat have 2 connection(1 normal open connection and 1 is normal open connection),and it necesary to put your conection on open connection.
Dec 01, 2013 | Whirlwind FH-778 Air Conditioner
Gas furnace does not come on
You should have 2 blue wires as well down at furnace connections. Remove thermostat wires going to those 2 blue wires and connect those 2 blue wires together, ( make sure they don't touch anything else) with thermostat on heat setting. If 12 VDC power going to red & white or red and black at furnace, connecting those 2 blue together, should start furnace. If not problem at furnace, if it does start, problem at thermostat or wiring to it. All that does is by-pass thermostat to confirm where problem is.
Jan 08, 2013 | Dometic Rooftop RV Air Conditioner
Our Carrier Furnace will sometimes work fine, however, at times, it will just not go on. Our thermosat is set to 68 and many times it will drop to 65 or even 63 without turning on. It happens every so...
obtain the code it flashes on the board next time it goes down and let me know what you got. There are too many variables to guess Id rather hit it right on the head. I will be waitiing for your response. The board is usually located in the blower section of the furnace.
Dec 16, 2010 | Carrier 38CKC036 Air Conditioner
Changed thermosat no power
Check for 24 volts across the red and white wire. If no, broken wire, bad fuse or bad board. If yes, bad thermostat.
Feb 16, 2010 | Carrier TSTATHCP Programmable Thermostat...
Two air conditioners & two furnaces with one thermostat
use relays to combine the to and isolate from each other or observing polarity's, you should be able to parallel the connections from your thermostat
Jan 28, 2010 | Dometic Rooftop RV Air Conditioner
THERMOSAT IS SET FOR 71 BUT SOMETIMES WILL NOT COME ON TILL 66
There should be a setting on your thermostat for +/- most are default set for +2 -2 check your settings at the thermostat
Jan 09, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a DuoTherm BriskAIr 13.5K BTU. The Dometic thermostat also controls my HydroFlame 8531-IV furnace. This morning, the furnace would not come on. I checked the wiring and there is no voltage at the...
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Jul 08, 2009 | Dometic Rooftop RV Air Conditioner
One of two Central Air Units is not working - thermostat works
Ended up being the wires going to the thermosat, was clicking on like it should so we thought it was working, however, it was not... as a temp fix both air conditioners are running off of the same thermostat, and the new one will go in today
May 29, 2009 | Heating & Cooling
Heating & Cooling Logo
66 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
