Question about Gateway Netbook N450
Battery has been charging to 100%. Suddenly would only charge to 76 percent. Now, after two weeks, will max at 62 percent. Computer is 1 year old. Can battery meter be recalibrated?
  • 3 Answers
Maybe you have better buy a new one, sugget new replacement battery on http://www.digi4travel.co.uk .
Posted on Apr 11, 2011
    Problem Solver:
  • 16 Answers
Im not sure which model your gateway is but this solution has been know to work for some models. Follow these steps to recalibrate the battery.
  1. Disconnect the AC adapter
  2. Turn on the notebook computer.
  3. As soon as it starts and you see a startup screen, press the F2 key.
  4. In the BIOS Setup Utility, use the TAB key to select the Advanced menu.
  5. From the Advanced menu, select Smart Battery Calibration, and then press the ENTER key. When prompted, start the recalibration program.
  6. After the battery has been fully discharged and your notebook computer has turned itself off, re-connect the AC adapter and fully recharge your battery.
Recharging may take several hours. After the battery finishes recharging, the battery meter displays the accurate battery charge.
Posted on Mar 11, 2011
    Novelist:
  • 134 Answers
Pulled from Gateway's website:
Do not interrupt the battery recalibration process. If recalibration is interrupted, you must start the process over again.
  1. Close all open files and programs.
  2. Connect your notebook to AC power and allow the battery to completely charge.
  3. Disconnect the AC power and restart your notebook.Note: If the power cord Battery has been charging to - plug.gif or battery baticon.gif icon does not appear on the taskbar, click the show hidden icons button. If the icon still does not appear, verify thatAlways show icon on the taskbar is checked on the Power Options Properties Advanced tab.
  4. Completely discharge the battery by doing the following:
    1. From the desktop, right-click on the power icon, then select Adjust Power Properties.
    2. Click the Power Schemes tab.
    3. Click the arrow button to open the Power Schemes list, then click Always On.
    4. Click the Alarms tab.
    5. Click to remove the check mark from the Low battery alarm and Critical battery alarm checkboxes. Let the battery drain until your notebook automatically turns off.
  5. After the battery is completely drained, reconnect your notebook to AC power.
  6. Charge the battery completely until the yellow battery status indicator goes out.
  7. When you are ready to use your notebook again, do the following:
    5. Click to select the Low battery alarm and Critical battery alarm check boxes.
How long for battery recharging D610 ?
when the computer is turned off, the AC adapter charges a completely discharged battery to 80 percent in about 1 hour and to 100 percent in approximately 2 hours. Charge time is longer with the computer turned on. You can leave the battery in the computer for as long as you like. The battery's internal circuitry prevents the battery from overcharging. So About 2 to 3 hrs
When you connect the computer to an electrical outlet or install a battery while the computer is connected to an electrical outlet, the computer checks the battery charge and temperature. If necessary, the AC adapter then charges the battery and maintains the battery charge.
If the battery is hot from being used in your computer or being in a hot environment, the battery may not charge when you connect the computer to an electrical outlet.
Jun 06, 2014 | Dell Latitude D610 Notebook
My nokia 2700 battery is draining very fast
This is usually because it has reached the end of its life or has a bad cell internally. Cell phone batteries are designed to last just about two years and then the service provider coincidentally doesn't carry them anymore forcing you to upgrade. This is part of the scam cell phone companies pull on customers. Its max charge is lower than it used to be so when you charge it to 100%, its really only 100 percent of its now lower capacity. Think if it like this, you fill you water bottle to 100% so its full. Every time you use it, its an inch shorter. So the next time you fill it, its filled to 100% capacity but its still less water because its only 100 percent of smaller size. Same thing with batteries, as they age, their full capacity becomes smaller. I would go to Amazon and do a search for a battery for that phone. I did this with my Droid X and got one for $7.
Sep 20, 2013 | Cell Phones
Why doesn't my hp notebook charge?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 08, 2013 | HP Pavilion Computers & Internet
I have had my i phone for three days but will not charge beyond 50..percent...help
If the re-chargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 14, 2012 | Apple iPhone 5
Lap top battery charging, LEDs not light but charging battery up to 76 %
Oct 02, 2012 | Fujitsu Siemens Computers & Internet
Battery charging LEDs not light but charging up to 76 %
Oct 02, 2012 | Dell Latitude X200 Notebook
Acer Aspire battery level suddenly drops 80 %
Have you seen inside a laptop battery, it's not just a battery. It also has control circuitry inside, could be that. Not usually repairble but you can do some makes of battery. See here:Circuit.
Personally I would buy a new battery.
Jan 27, 2012 | Computers & Internet
I bought a replacement hp battery for my HP Pavillion zv5000 a year ago. It was working fine for about 6-8 months. Then, it seemed to stopped storing energy even when the charging light stopped and...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 08, 2011 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
The battery only charges to 50%- down from 100 percent just a month ago.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all. A new replacement battery will fix this problem.
Dec 20, 2009 | HP Pavilion dv6000z Notebook
Dell inspiron 1501 battery won't recharge fully.
Laptop batteries last 1 to 3 years (check your warranty = most laptop batteries are only 1 year ..) .. anyone who gets 3 years out of one is doing well ...
Mar 15, 2009 | Dell Computers & Internet
Gateway Netbook N450 Logo
794 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
