How can I connect my JVC TV to my HP pavillion laptop using a VGA-to-RCA cable. Recently I tried it but nothing happens
  • 635 Answers
Assuming you connected the PC to the component input of the TV using this cable
how can I connect my - bobhifi_12.jpgNext right click on desktop / click properties / click on settings / Move the resolution pointer to a lower figure like 800 by 600 to start with / click apply / say yes to this settings / Connect to TV and it should work
Posted on Mar 11, 2011
How do i connect my hp2560p to tv
You can use a VGA cable to connect from your laptop to your TV.
10FT 15 PIN BLUE SVGA VGA ADAPTER Monitor Male To Male Cable CORD FOR PC TV
Just make sure you have a connector on your TV....If you only have RCA inputs, you can buy an adapter. just plug it into your laptop and run the Red, White and Yellow to your TV with RCA cables.
VGA SVGA to Video 3 RCA AV TV Out Cable Adapter Converter PC Computer...
Thanks Hope this helps!
Please rate
Gary
Mar 17, 2014 | HP Elitebook 2560p Notebook 12.5" 2.5gI5...
Conecting computer to view screen
Hello
Your JVC Tv has AV & Component video inputs only. No direct connection facillty with computer is there. Computers outputs VGA stream video. VGA stands for Vodeo Graphics Arrey. This video stream cannot be connected directly to your JVC set. There are sets, which have this facility, but your set have not.
If you want to connect this set to computer, you have to buy one converter [VGA to RCA out], from open electronic sparepart selleing shops at your town. It will not cost more.
If you have this converter, you can connect your computer directly to the VGA converter, using a VGA to VGA cable, and the output from the converter by RCA connecting wire to TV. In short, the converter will be in between TV and Computer.
VGA to Video converter will look somewhat like this. OK.
Dec 14, 2011 | JVC AV-32D305 32" TV
I have a vgn-a150 laptop, and am trying to hook it up to my hp flat screen tv. I tried a video connection to the tv's rca jacks, but nothing. So I tried to connect vga to vga, but still nothing. ...
try a coax or composite cable.make sure they are properly connected and check the settings on your laptop (display settings) depends on the computer's operating system
Jul 27, 2011 | Sony VAIO VGN-A150 Notebook
I have a 25" JVC
Try pressing Fn + F5 on your laptop to output the TV. Alternatively, on the display driver of your laptop there is a properties to use as a dual output.
Mar 11, 2011 | Televison & Video
Im trying to hook my insignia d400 to my jvc hd tv i have a vga cable that converts to rca cables and s-video cable and nothing shows up on tv
Does your TV not have a PC connection? It looks like and IS the same as the Connection on your PC. If so, get a standard VGA male to male VGA connector cable from your local PC shop and use this. The adaptors you are using won't be seen as PC input. You will need to also connect a PC audio cable between them to get sound. When you have installed these, using your remote control, select "scource" as PC and you should be away! Good luck. Ian.
Jan 24, 2011 | Computers & Internet
Laptop to tv
Your model laptop has S-Video out capabilities. Depending on what model TV you are connecting to, you would then need an S-Video to (whatever input connection your TV supports: S-Video, VGA, RCA, HDMI) cable. Once you have the cable connected, set your TV to the input method for the cable used, and press Fn + F4 on your laptop Keyboard to project the image over. May need tp press more than once depending if you wish to only display on one screen or both. S-Video is only a video out cable, so you will alos need to run an audio connector cable from your laptop to TV as well, or just use a pair of external laptop speakers for your sound.
Jan 12, 2010 | Computers & Internet
Vga cable connects TV to HP laptop...then what?
You have to enable VGA port on the laptop. Press Fn + F5.
Nov 15, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Connect to a tube TV
hi mr. pavilion dv6700z. i have the same problem before but after i tried and use my genius mind. i made it. and the television is working in my laptop as a external monitor. pixel is good. just connect in card video out to video iput to television. romsky79@yahoo.com.
Jun 06, 2009 | HP Pavilion DV6700Z Notebook
Connect Laptop to TV
It depends on what kind of TV you have. If you have a flat-panel LCD or plasma TV, it may have a VGA connection already installed. If that is the case, all you need is a standard VGA cable to connect from your notebook to your TV.
If you have a TV without a VGA connection you will need a scan converter to convert your signal from VGA to RCA or composite video signal. These can be purchased online or from electronics stores like Radio Shack. You plug your VGA connection from the computer to the scan converter, then RCA or composite video cables from the converter to the TV.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | HP Compaq 8510p Notebook
Connecting Dell Inspiron 1501 to TV, Windows Vista
The PC card you have doesnt appear to work with that adaptor. Dell Has its own Svideo / Video output adaptors.
You need a converter not an adaptor. Try looking on Amazon for this: ITV-900 PC to TV Converter
Dec 23, 2008 | Dell Inspiron 1501 Notebook
Televison & Video Logo
433 people viewed this question
Top Televison & Video Experts
