Question about Sony VAIO VGP-BMS33/B
My laptop is less than a day old. right click was working when I was setting up my computer, and now on the second day of owning it it stopped
  • Sony Master
  • 32,281 Answers
I suggest you return it to the place where you bought the laptop and have it replaced or repaired under warranty.
If you try to repair it yourself you might void your warranty.
Posted on Mar 11, 2011
The sound comes and goes on my Toshiba C655 laptop. It goes out then comes back on its own. All indicators say the sound is working fine, the speakers are fine...the mute is not on...no help with...
if the laptop is less than 6 months old you should still have warranty you could retutn it on a warranty issue before you touch anything but you could attempt some basic troubleshooting
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 09, 2011 | Toshiba Computers & Internet
The CD/DVD/ drive can not read any CDs even I set the region code. It makes noise that sounds like reading the CD but actually it does not. It cannot recognize any media in the CD drive. I could not even...
wow a really top of the line laptop that has a faulty cd drive!! well well. i suppose that laptop is less than 3 yrs old right? well if i guessed right then you may have warranty coverage. thats your best bet to keep it under warranty. this advice is much much less of a hassle and hp has a 2 day turnaround on warranty repairs so youll have your system back in no time. they pay for shipping bothways.. well good luck take care..
Dec 02, 2010 | HP Pavilion dv7-1240us Notebook
I can not switch on my mini laptop (Dell Inspiron mini 10), The power button is just lighting on. Within seconds the light disappeared. I took the battery out, but now is also no light on the power...
The power module in your motherboard is malfunctioning. Is the Dell notebook less than a year old? If so, go to www.dell.com and click on Support and go through the process to get an RMA code. You will then be told how to send the notebook back for repair. It will probably take at least 10 working days. If the notebook is over a year old, contact you local computer repair or go to eBay to look into getting a new motherboard. Perhaps, it's time to look for a new PC; they make them to fail these days. You are lucky if you get to 2 years in many cases.
Oct 31, 2010 | Dell Inspiron Mini 10 Notebook
I have a 23" screen but the setting seem to be set for a small screen. I can barely read the font. The settings had been fine until one day last week and they simply changed on their own. What can I do...
assuming your using win XP or some other OS right click on your desktop and click Properties at the bottom , then click settings tab at the top , you should see at the bottom of the window screen resolution with a slider bar less or more , you can change the screen resolution to what works best for you
Sep 20, 2010 | ASUS VH232H 23" Monitor
Screen won't work on new computer
Reconnect the old monitor.
Start Windows.
Right-mouse click anywhere on your "wallpaper".
Click Properties.
Click Settings.
Move the slider to 800-by-600 or 1024-by-768.
Click Apply
In 'Advanced', set the refresh-rate to 60 Hertz.
Click OK.
Shutdown.
Reconnect the new monitor.
Restart your computer.
Click Properties.
Click Settings.
Now try moving the slider to higher values.
If the screen goes blank, wait 15 seconds, and Windows will cancel your change to a higher value.
Apr 07, 2010 | Westinghouse 25.5" Widescreen Flat Panel...
Computer does not recognize CD/DVD drive
If updating the drive firmware does not work, then replacement of the drive will be necessary.
Jan 30, 2009 | HP Pavillion ZV6000 Notebook
Tv turns it self off after only 2-3 seconds and makes crack noise
Since the set is less than 1 year old, it should still be under warranty. Request warranty service.
The noise you are hearing is probably arcing inside the set on the power supply board. Continuing to attempt to turn on the set will only make things worse. Please request warranty service as this is unusual for a TV that new.
Dan
Jan 16, 2009 | LG 50PB4D 50 in. Plasma HDTV
Computer is TOOOO SLOW
probably due to all of the stuff in your startup folder a new pc comes with. the less stuff in your startup the better. you may need a memory upgrade of 1GB or less. I would go at least to 2GB of RAM
Jan 12, 2009 | IBM ThinkPad T60 Notebook
Alps pointer device driver
Dont give much pressure or harder press over the area and on the keyboard on your laptop. If any pressure on top area will makes your touch pad to start working all laptop has it option to off it . Also make your mouse sensitivity very low - if you set it in high a small movement or any kind or pressure over that can make it on.
May 18, 2008 | Compaq Presario 700 470024-192 Notebook
Left click button below touchpad on dv8000 not working
Sarah it might be due to Hardware malfunction i think you should replace the switches+touch pad! can i know how much old is you laptop? most of the touch pad needs to be replaced when used more than 4-5 years!
Dec 08, 2007 | Compaq Presario M2000 Notebook
Sony VAIO  VGP-BMS33/B Logo
124 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
