Question about Maytag Dryers
The dry will not start the display or dig. Controls wont engage anything the start button keeps flashing was just working great
  • 314 Answers
Bad Heating Element
Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
Broken Motor
Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
Bad Switch
When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch
Posted on Mar 11, 2011
Dryer takes for ever too dry cloths
Posted on Apr 28, 2011
The start button keeps blinking, WONT LET ME DO ANYTHING
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
Sharp comfort touch air conditioner screen doesnt show settings and buttons wont work after cleaning. help its hot!!!!!
Switch off the unit at the isolator or fuse box. Leave off for 10 mins to reset. When powering up again and it still wont work, check your remote control batteries are good. Also confirm you haven't "blanked out" the display. Some controls have a display or LED function which blanks out the display so that the lights are not bright at night time. (For bedrooms so that the light doesn't keep you awake) Also check that you have not pressed a "child lockout button" This will stop anything ..
Jul 25, 2013 | Heating & Cooling
The tv button is the only button that flashes and wont let me set up
The fault is with the main system control memory IC to your TV. Check and replace it.
Feb 13, 2013 | Televison & Video
My dishwasher wont start everytime I hit the start button the green light that says it's clean flashes. How do I fix it??
this just happened to me and i pushed high tem wash, heated dry, high temp wash then heated dry and now it works great. good luck and save some money!
Mar 16, 2011 | Dishwashers
Heat/Dry button
My motto with all electrical systems is: If all else fails reboot. Find the breaker that controls the dishwasher and switch it off for a couple of minutes. this will clear out the electronic buffer. and reset the systems. make sure that the door is not closed, reset the breaker and try to restart your dishwasher.
May 16, 2010 | Kenmore 13593 Stainless Steel Built-in...
Display frozen
I think if you push the heated wash and heated dry buttom several times until all the buttoms light up this may fix your problem.
You may have different kind of light flashing indicator, but the same solution.
Possibly check the sequence switch
Feb 09, 2008 | Dishwashers
Machine won't start and the START light keeps blinking
A flashing start button shows that the filter is dirty. Remove the filter assembly from the machine. The "tube" can be split into 2 sections fairly simply - do so, and wash each piece under the tap to clean it.
Once the assembly is cleaned properly, select the program that you desire, and press and HOLD the start button for 2 seconds. The wash cycle should begin.
Nov 05, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dryers Logo
243 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
