Question about Poulan 18" Wild Thing Chainsaw
After long storage, cleaned carb, replaced fuel lines, new spark plug. Won't try to fire at all, even with starter fluid sprayed in cylinder, hooked up spark tester light -- no sign of spark. Any guess on likely part of ignition portion to test/replace?
    Master:
  • 403 Answers
You say you cleaned the carb, most importantly, did you clean the jet in the carb. if not there your problem. The ethonal in gas will gum it up in a heartbeat if not run.
Posted on Mar 11, 2011
Poland Pro BVM200VS has fuel in primer bubble and spark plug is getting fire but won't start
Try spraying some starter fluid into cylinder thru carb opening around throttle plate. If it starts ever so briefly then the carb is not delivering fuel to the motor. Needs rebuilding or replacement.
Nov 26, 2015 | Garden
Why won't the motor run?
check to be certain that the fuel filter and fuel line is clear and working properly. try using your starter fluid through the air intake and not the spark plug port.
May 04, 2015 | Garden
I have a Husqvarna 375k cut off saw. It has spark, rebuilt carb, good compression, I even sprayed a little starter fluid in the cylinder and it won't even try to fire. Definitely has spark
try taken the spark plug out , using the starter cord slow pull on the string. Looking inside where the spark plug was, does the cylinder move up and down?
If it does you might have a bad ring around the cylinder.
One last thought, make sure that the spark plug is clean and re-gap correctly.
Apr 08, 2015 | Husqvarna Garden
Will not start even withew gas
Try a spray of starting fluid into the carb. If it fires you know you have good spark. If it did not fire replace your spark plug. If it still won't fire point and condensor need to be replaced. If it did fire spray the starting fluid in the carb a few more times to pull the old fuel through the fuel line til the new gas gets through the carb and then it should run. Some machines have a fuel shut off valve make sure it is open.
Dec 13, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
I have a 1985 Yamaha maxim that hasn't been ran
Spray starter into the carb intake with no choke, if she runs for a few seconds then you know its fuel starvation
clean jets & airways & blow through with compressed air
Nov 20, 2011 | 1985 Yamaha XJ 700 S Maxim
I have a new batiere in my 1991 vino 50cc tow stroke, And the starter wont work and it wont kick start even with starter fliod. Anything that I can check or replace?
Check fuses. Get a new spark plug then check for spark by hooking up the plug wire then hold the metal side of the plug against the cylinder. Have a friend kick the engine over while you look for spark. Remove the carb, then remove the float bowl from the bottom of the carb. Use spray carb cleaner to clean the carb. How old is the gas? Flush the tank and fill with fresh fuel if old gas is present. Please rate my answer. Thanks.
Apr 06, 2011 | Yamaha G5 Motorcycles
I have a 98 honda foutrax 300 4 wheeler it started acting up and now it wont start took the carb. off and cleaned the jets and everything up and pulled the spark plug out and put my fire over the hole and...
remove all of the old fuel using a siphon bulb and hose. Put in brand new fuel and make sure the line from the tank to the carb. is flowing gas. if not clean or replace the fuel line
Jun 17, 2009 | Honda NS 250 R Motorcycles
Coleman Powermate 5000 starts with starter fluid, but leaks gas into the air filter. Checked the float, it has no holes, and is not jammed. Fuel will go into the carburetor, but no fuel will reach the...
Sounds like you need to clean the carb ports, lines, jets, etc... purchase a carb spray cleaner with a tube to place on the spray head (Berryman's Chemtool B-12 is awesome). Take the carb loose from the generator, and remove the bowl, needle valve and spray carb cleaner thru all the holes, lines in the carb. Reinstall complete with air cleaner and retry... also if the gas is old, drain and replace with new...
May 25, 2009 | Coleman Powermate Powermate 5000W...
Poulan 18" Wild Thing Chainsaw Logo
97 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
