Question about Miele 24 in. Novotronic G641 Plus Built-In Dishwasher
The Miele G641 Plus is tripping the power switch half way through the wash cycle.
4 Suggested Answers
  • 249 Answers
SOURCE: Candy cs455 m dishwasher tripping out power
check heating element
Posted on Mar 21, 2008
vickygomar
  • 460 Answers
SOURCE: Miele G570 dishwashher tripping ELCB at end of
this information will help U  please copy n paste
http://www.youtube.com/watch?v=nr6tIO5iNSc
If you need more assistance please contact us.
Was this helpful?
Posted on May 13, 2009
  • 70 Answers
SOURCE: need a handbook for miele g641 plus dishwasher
http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf
Posted on Feb 03, 2011
Miele G641 SC Plus Drain /inlet light 4 short 1 long flash. How do I find a fault code chart?
Inlet / Drain is a general fault meaning there was no water movement when it was necessary to start the pump. Either it didn\'t drain out or it didn\'t fill the last time.
Call 800-999-1360 for free Miele tech support. They will advise you free of charge. You will perform step by step control board operations over the phone to clear the fault code as well as advise you how to cleanout the drain pump.
Dec 27, 2014 | Miele Dishwashers
Miele dishwasher g1220sc has stopped working. There is no electrical activity viewable in the control panel. Has anyone experienced this before? Any solutions / suggestions?
Hi Lisa itsounds like a door latch , if it goes bad it has two safty switches on t to prvent useing the dishwaser while the door is open,before you order any parts check to see that you still have power to the unit , check braker
Dec 16, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Have miele dishwasher g641 inlet/outlet light flashing the water is going in and is draining starts flashing about 5/10 mins after starting do you know what else to try many thanks janet
Just encountered exact same problem - happened after attempting to clean very greasy pans so grease/oil created foam/more or less solid material in filter area, but as well in pressure switch (pn 4859640)
This seems to be the cause (not sure yet)
Mar 07, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Inlet/outlet light keeps flashing on G641 dishwasher - have checked filter and cleared debris. Just completed a wash but dishes not washed or rinsed adequately. Anything else I can check before requesting...
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a
laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely. See what part of the cycle the unit lights up the fault. If it happens at the very start it is the drain. If it drains ok then fails it is the inlet. If it fails after that it could be any number of things.
Hope this helps.
Jan 26, 2010 | Miele 24 in. Novotronic G641 Plus Built-In...
Where is fuse located for Miele G641 Plus dishwasher and how to replace it?
hi,
there is no fuse on this model. first thing to do is check the incoming power at the socket. you can also find the electronics which control the unit all behind the door handle. Check there is power reaching the control electronics.
underneath the unit there are the components like the drain pump, circulation pump,hoses, pressure switch, relay for the heating, water sump etc which are all driven by the control electronics behind the door handle. you will find about 6-8 screws holding this front facia panel on. Remove this and firstly check all the connections are good. you may find a plug has just worked loose.
Hope this helps.
Nov 21, 2009 | Miele 24 in. Novotronic G641 Plus Built-In...
I have a Miele G641 dishwasher and it wont drain and it is coming up with red lights saying inlet/outlet, salt intake
One thing these guys did not point out is to turn the knob to STOP before starting this procedure (otherwise you will be ignored) Once done this works fine.
-- from the manual ----------------
Before rectifying the problem you must:
- Turn the programme selector to the "Stop" position.
- Switch the dishwasher off using the "On/Off" button.
Nov 15, 2009 | Miele 24 in. Novotronic G641 Plus Built-In...
Salt light on G641 model
i turn the dishwasher on the salt light keeps flashin ive cleared out the salt container and applied new salt and its still not working
Jul 08, 2008 | Miele Premier-Plus Built-in Dishwasher
Miele 24 in. Novotronic G641 Plus Built-In Dishwasher Logo
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
