Question about LG 23LC1RB 23 in. LCD Television
LG 23LC1RB TV Capacitor blown on power supply board C201 any idea of the value?
  • 5 Answers
Try this link
capacitors.best-price.com
hope this helps?
Posted on Mar 11, 2011
I have an older model LG TV that gets a perfect picture and sound for about 15-20 minutes, then goes to a black screen with various lines and no sound?
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Jun 10, 2015 | LG 32LC2D Television
Tip
LG 42" PLASMA TV CLICKING WILL NOT TURN ON REPAIR
Hi
Ok everyone, this is a very common fault on this model of tv power supply, just keeps clicking on and off.
Your power supply board number should be.. 6709900019A
To resolve the issue we need to change some bad capacitors in the supply these are all the same value 3300uf / 10v
C227 / C201 / C202 / C203 / C281 / C282 / C283 / C271 / C272
All these need to be changed for the same uf but try and use a higher voltage, lets say 3300uf / 25v
Upon replacement your power supply will be like new and your tv will fire straight up.
Hope this helps a few people
on Apr 05, 2010 | Televison & Video
Tv is not displaying
Your tvs power supply board probably has a blown capacitor. Just open up your tv and check that all the capacitos37d77cb9-7d6e-45ea-8be1-2a8ddfb09adc.jpga5fe926a-58ed-4064-87cc-b4564a7e4e5e.jpg
As you can see in these photos the capacitor is blown or leaked.
Hope this helps
Dec 30, 2013 | LG Televison & Video
No power coming out of the power supply. Most of capacitor were changed, but it didn't help.
Check your fuse on the power supply. If it is blown, change it with same value fuse and hope it doesn't blow again. If it does, or it wasn't to begin with, then you need to replace your power supply.
Apr 19, 2011 | LG 37LC2RR 37 in. LCD TV
Heard a pop noise from LG 60PC1D tv, tv shut off and now the picture looks like a negative kind of...what is wrong?
Capacitor on the power supply popped and it is not allowing the proper voltage to be reached to the main board. This is messing up your picture. I would repair it before you create more damage from the blown capacitor on the power supply.
Please rate if this helped :)
Mar 08, 2011 | LG 60PC1D 60 in. Plasma Television
My TV turns of and on by itself
It is power supply mistake. There are regulators fitted inside your tv circuit board, which are directly soldered to printed circuit board. After years of age, the soldering points gets heated and cooled, as the regulators will get heated while working. Re-solder the junction will rectify the problem.If it does not help check for any short circuit in it. A small value high voltage capacitor fitted to the collector of the horizontal output transistor, usually [330pf 2000v] will get shorted to earth. If it gets shorted it is an effect of direct short to the 120vDC power supply rails in your tv
or
There's a problem with the power ic board. Open it up and look for a burned capacitor. De-solder the piece out and replace with a new one that matches the same specs
i.e. bad capacitor in power supply
Dec 06, 2010 | LG Televison & Video
Bush lcd27tv006hd no power ,no stndby lights
Open the back cover of the monitor.. check the fuse at the power supply board... If the fuse is open, replace with same value.. at the power supply board check for any blown capacitor and replace it with same value. Check also the power cord for open connection.
Feb 04, 2010 | Bush 5693D 24" TV
My lg tv wont turn on.
First, I would try leaving the TV unplugged for an hour so the TV can discharge and reset itself.
If this doesn't work, it maybe something simple like a blown fuses inside the TV that needs replacing.Radio Shack or some electronic store will carry the fuses.
If the other two ideas doesn't solve it, we're talking about a power supply board related problem. I can't actually look at your TV over the internet. But, the most common problem with flat panel TV are the power supply board for the screen itself and the main power supply board for the rest of the TV. Commonly a bad capacitor or transformer will be on the board.
If you have some electronic experience and want to repair it yourself, you can sometimes find a Service Manual for your TV over the internet. Normally, costs less than $20. It will have diagrams, schematics, and part number list for the TV.
Sep 09, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
LG 23LC1RB 23 in. LCD Television Logo
213 people viewed this question
Computer Repairing
Computer Repairing
