Question about Andis AGC2 Hair Trimmer
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades won't remove any hair... motor seems to still be working properly... At a loss....
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Posted on Mar 12, 2011
  • 30 Answers
If the tension is off on the blades it will not cut properly. You may have to send them into a qualified sharpener to have them checked.. They also could be dull.
This can happen if you completely take apart the blades.
Also, the clipper itself should not need to be disassembled to be cleaned out and lubricated. Just the blade will snap off the end, and you can brush it out use a liquid blade wash to disinfect and remove the hair from the blades, then lubricate with clipper oil.
Make sure the blades are cutting clean dry hair, and if that still doesn't solve it try a different blade.
If your clipper is under warranty then you may need to send it for service.
Hope this has offered some assistance.
Posted on Mar 11, 2011
How to reassemble blades on wahl stable pro 8800
Do you have more parts in your hand than 2x screws and 2x blade parts? If no then pop the small cutter blade onto the plastic blade drive with the drive engaged into the diamond shaped hole in the cutter blade. Make sure you put the cutter blade on with the teeth facing forwards and the correct way up. The top side (goes towards clipper) is pretty much flat except where teeth taper. Next lubricate the small cutter where it is going to touch the large comb blade when you fit it. Now put the comb blade on and fit the 2 screws. Line up the blades & tighten the screws.
Apr 20, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
Clippers have suddenly stopped cutting and seem to pull at the hair
Generally removing the two screws.. on the blade foot (don't do this over the sink unless the drain is closed!).. and taking the blade apart.. cleaning the trimmers with a small brush.. apply grease in the blade groove.. reassemble
Usually it's best to put those two screws back just get them in lose.. not quite snug..set the blade upside down on a flat surface..so it pushes the blade back away from the cutting end..level..then tighten those screws while you are pushing or holding down on the clippers cutting edge against the flat surface/table. ... oil the blade with the proper oil or a light mineral oil.
This usually will get them back to cutting properly..the blade should be oiled prior to each use...about two to three drops right along the visible part..or a light spray also hair should be clean.. dirty hair does not cut well at all..and the clippers will tug and pull rather than cut cleanly.
Lastly..if they see a lot of use. might be blade replacement time..
Best of luck!
Apr 13, 2011 | Oster 76076-010 Hair Trimmer
I have a brand new set of Oster A5 model #78005 clippers. We own two large dogs--we cliipped the first one and it worked beautifully--we were about half finished with the second one and all of a sudden...
I'm sorry if this sounds academic, but regardless of whether or not the problem lies with the clipper or the blade set itself, since it is brand new, return it to the seller.
Apr 09, 2011 | Oster Golden A5 2-Speed Universal Motor...
Instructions on how to clip my dogs hair.
  • Set the dog hair clippers to the 9-10 setting. Use this setting to clip your dog's undercarriage. Undercarriage refers to your dog's armpits, **** area up to the tail, and stomach.
  • Set the clippers to the 7-8 setting. Clip your dog's legs and paws with this setting.
  • Use a comb to pull your dog's hair away from the eye and muzzle area. Set the clippers back to the 9-10 setting and clip all around his face, ears and head.
  • Rinse your dog with clean water or give him a shampoo to remove all of the excess hair you clipped off. Blow drying him may be necessary if it's during the colder months of the year.
  • Apr 03, 2011 | Health & Beauty
    How to reassemble blades on Wahl rechargeable unit
    I had the same problem and I eventually figured it out. The blade assembly has to be reassembled first then snapped back into place.
    1. the bottom part has a little "nub" that the screws attach to
    2. the second part is the thin piece of metal with a ridge
    3. the white plastic thing, make sure the ridges are sandwiched together
    4. the small blade, the blades must face each other
    5. the large blade
    use the 2 screws to hold the assembly together, once assembled it snaps into place on the clipper. See attached picture for how it should look once assembled.
    It's STUPID that this is missing from the instruction guide that comes with the clippers.
    Mar 15, 2010 | Wahl 8550
    A5 dog clipper or blades may need tune up or
    some times the link and gear inside the front part of the clipper wears out and the blades just wont cut. try this, remove the clipper blade on the front of the clipper their is a lever color red grab this part with your 2 fingers and move it side to side if it moves and feel sloppy your gears and link are worn out. you need to replace, also check the hinge for spring tension. if you need help Contact mannyssharpening@yahoo.com
    Feb 22, 2010 | Oster Golden A5 2-Speed Universal Motor...
    Andis Ultra Edge Pet Clipper Assembly Help
    I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
    Aug 13, 2009 | Andis Health & Beauty
    Andis pm-3 dog clipper won't cut anymore!
    I have had this same problem!  I bought new blades, sharpened old ones, and nothing worked.  Finally, I went to an authorized service center and they couldn't figure it out.  Then the tech. pressed on the blade (the outside bottom one) and it cut!  When you remove the blades with the 2 big screws, there are 2 more smaller screws inside under the smaller blade.  One of those was not screwed in tightly.  That was all it was!  I guess they jiggle loose.  I hope this helps!
    peony
    Mar 02, 2009 | Andis ProMotor PM-3 Hair Trimmer
    Andis AGC2 Hair Trimmer Logo
    857 people viewed this question
    Top Andis Health & Beauty Experts
    Anglia Clipper...
    shaveroutlet.com
    shaveroutlet.com
    Kolbrun...
    Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
