Question about Plumbing
I have a bathroom lavatory faucet , white in color , single handle by the manufacturer "Bormix". I think it is a Scandinavian brand. I can't find a replacement for it anywhere. I love the item but is 24 years old and has calcium deposits. Where can I find one like it?
  • George Scott
    George Scott Oct 02, 2017
    Well hells/bells--there's on on ebay item # 302294345314
  • 586 Answers
All I can think of is to do a google search for "Bormix" and hope you can find them. As a matter of curiosity, where did you purchase it, and when? Maybe contact the installer - if he is still alive. Last option would be to remove it (very carefully) and clean it out with some sort of tool for such things, then replace it (also very carefully). If I had your problem, I would just replace it with a new high-end faucet. After all, 24 years - c'mon. You've gotten all the use you could possibly expect from it - and way more.
Posted on Sep 18, 2017
  • 9 Answers
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
  • 117 Answers
SOURCE: I just installed a new cartridge in a moen single
try and pull the cartridge out and look in there with a flash light and make sure there isn't any think lodged in the hot water side of the faucet, you might even want to leave the cartridge out and turn the water back on to try and flush it out. alot of times rubber from the old cartridge gets stuck in there as you are pulling the old one out especially if it's stuck in there good
Posted on Jul 29, 2009
  • 72 Answers
SOURCE: Severely reduced water pressure from lavatory faucet
Take the strainer off the spout and check to see if there is any dirt or rust buildup in the strainer. This happens when repairs have been done. It usually collects at the first place the water comes out of.
Posted on Nov 07, 2009
  • 6674 Answers
SOURCE: how do I fix a dripping MOEN T4572 lavatory faucet
If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
No charge.
Posted on Jan 22, 2010
  • 94 Answers
SOURCE: trying to put new cartridge in my moen bathroom
shut water off under faucet,open it to prove wtr is off. pry off cap , slide edge of putty knife,butter knife.etc should see a phillip's screw.remove,pull handle off, pull chrome sleeve off, now. toward's top you should see a little tab sticking out, it is part of a horse shoe shaped clip,pull with needle nose plier's,or attention how it come's apart ,your new cartridge come's w/detailed instruction's,calmly refer to 'em, you may need or may not need a moen cartridge puller,(use a good grip,steady pull,)
Posted on Apr 26, 2010
My bathroom faucet drips. How do I repair?
there is a seal in the valve assembly that is warn they usually dell kits for it from a hardware or home depot store
Sep 11, 2014 | Plumbing
How do I replace a cartridge for kohler bancroft sink faucet?
kohler bancroft is the sink manufacturer, not the faucet mfgr. do you have a clue what faucet mfgr it might be?
Jan 14, 2018 | Kohler K-10577-4-SN Bancroft Widespread...
Delta 2555-216 Victorian Double-Handle Centerset Lavatory Faucet with Metal I have a slow drip in bathroom sink and do not know how to remove the stem to get at the washer in the Victorian listed above.
If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
Sep 01, 2011 | Delta 2555-216 Victorian Double-Handle...
I am trying to fix a leaky danza single handle bathroom faucet. I cannot figure out how to remove any part of the faucet from the top to be able to change the washer.
There is a allen set screw on the handle it may have a cap over it locate it and unloosen screw and remove handle then un screw bonnet nut then replacement kits available at most hardware,home improvement,or plumbing stores take note of how the parts are removed so to reinstall the way they came out.
Jun 05, 2011 | Danze D203112 Melrose Single Handle...
I have an american standard bathroom faucet. Single handle. It is leaking where the faucet meets the sink. I do not see any screws to take off the handle. How do I fix it?
First, turn off the water supply under the sink. Next, put the faucet lever in the up position, no water should be coming out. While in the up position turn slowly while looking at the underside of the handle and you should be able to find a set screw. It will probable be an "allen head" type and you will need and allen head wrench to loosen it. An allen head looks like a hex shape, 6 sided I believe and is rod shaped. If you don't have one they come in sets at your local hardeware.
Jul 16, 2010 | American Standard - Lavatory Faucet -...
Plumbing Logo
984 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
