Question about Garden
I was using my "55"
    Novelist:
  • 155 Answers
First Check the Air FIlter.. since the plug is wet it probably is getting fuel.. so check the air filter first...
Lastly.. even if the plug is wet.. you may want to check the fuel pump diaphram.. fuel hose and finally pull the bowl off the carb.. or remove the carb and throughly clean it... even a little debris can cause problems.. but your description sounds a lot like a clogged air filter.
Fuel air mix - spark.. you checked one.. I suspect it's a bad mix.. lack of air. Also check the choke mechanism.. there is a lot of vibration needless to say.. if that came lose.. it may swing or fall into the closed position.. and choke off the air.. .
Best of luck
Posted on Mar 11, 2011
    Sergeant:
    Champion:
  • 250 Answers
First of all make sure the air filter is clean. Next I would dunp the gas out of the saw and put fresh gasoline oil mixture back in the fuel tank. Maybe a little condensation water got in the fuel you had in the tank.
How do I remove ads by dragon branch from Google Chrome?
You can disable the browser add-ons in Extension manager. This often works. You can even delete it by click on the remove option. And I believe there are useful guides on the Internet can help you safely get rid of that dragon branch. I drag one from google result and you may look at it to see if it can help.
RemoveItVirus com Your One Stop Virus Removal Solution
Jun 11, 2015 | Google Chrome
How can you buy just the saw for the 8" 2 in 1 pole saw.
after looking at reviews written on
http://www.chainsawsdirect.com/Earthwise-CVPS41008-Chain-Saw/p7224.html
Robert
Tried chain saw. Working on limbs about 12 ft above ground.
First limb about 3 inches diameter, Oak. Worked fine.
Second limb same size. Cutter slip off branch could not stop the saw from hitting ground. Broke case where it attaches to pole.
No parts, and no way to repair it as company had no idea what kind of cement/glue I could use. So one branch cost me $120.00.
Sent To Customer Service
Shawn
Like Robert my saw hit the ground and busted in the same spot (this will happen to you sooner or later) and you can not get repair parts, its now a door stop.
Pros: Easy To Use, Light Weight
Cons: Can Not Get Repair Parts
I am guessing you mean the entire cutting end of the saw too, I would get a new one either same model so you have a spare pole or find a another brand that definatly sells spare parts.
Ive never used a electric polesaw but have done alot of work with with longer petrol and shorter hydrolic polesaws, even top of the range they can be broken easily always keep the chain sharp, cut one branch at a time or small clumps on a hedge.
Commonly they get dropped cause they get really heavy extended a shoulder belt helps alot as do coffee breaks.
Or they get jammed in the branch being cut which can be really dangerous with a half cut branch, be ready to run.
Also never use from a ladder
Jul 07, 2014 | Earthwise CVPS41008 - 8" 6.5-Amp Electric...
My tree is about five or six inches tall and has three major braches that spread very wide compared to the height. one of the three major branches is getting longer than the other two. should I trim it?
This is an old post, but I didn't see any replys, so I decided to answer. Trees are pruned to help it obtain and maintain a desirable shape and to help it to make more branches and become fuller.
With that in mind, if you have one branch that is out of shape, by all means you can prune it. I would cut it just above a bud node. That takes the "vertical" growth away from that branch and forces the rest of that branch to grow "out" not "up" by making more lateral branches and become fuller.
Aug 09, 2013 | Jonsteen Company Giant Sequoia Tree Kit-...
Stopped running
If the saw got bound in the cut it may have popped the breaker on the saw. Find and reset it
Jun 14, 2013 | Remington 111409 - 01 6" Branch Wizard...
Doesn't cut
Have u taken the blade cover off and cleaned away all the debris? Is the chain slack enough?
May 15, 2013 | Garden
We heard a "buzzing" sound and it stopped when I
I had a similar problem. Everyone said must be the magnatron or the fuse ....turned out to be a burned out (visually melted) thermal cut out switch ($12) on the top side of the microwave. Had to get down inside the top of the microwave. The cut out switch was tucked away right up against the the microwave box. Hard to diagnose your problem without looking at the unit in question though, could be several different things. However, my philosophy when it comes to repairs...start with the cheap stuff first!
Jan 10, 2011 | Frigidaire FMV145K Microwave Oven
Chain keeps coming off
Normally, a loose chain will enhance it's ability to jump off when trimming small branches.
When installing and/or adjusting a chain;
1) install the chain, bar, and cover, and install the cover nut loosely
2) support the 'nose' end of the bar with a block
3) tighten the chain until it touches the bottom of the bar,
and then tighen the adjuster 1/8 of a turn more.
*this will make the chain just a LITTLE snug
4) tighten the cover nut, and then by hand CAREFULLY rotate the chain.
If you cannot rotate by hand, it is too tight. re-adjsut
** This proceedure must be used on ANY brand chain saw.
Here is why.
If the bar nose is not lifted upon adjustment, when cutting,
the nose will move upward, the chain will have a 'droop' away
from the bar and appear to have loosened while cutting.
Any contact with a small branch will flip the chain off of the bar.
If you re-adjust it improperly, the same senerio will occur the next cut.
Nov 12, 2009 | Remington Electric Chain Saw
Noisy, blade seizes, used two hours
Sorry but there is no help for this equipment. Remington went bankrupt and i have not been able to get parts.
Plus they,in the past, considered this a throw away unit.
Sorry for the news.
Good Day.
Oct 27, 2009 | Remington At3017b Hedge Wizard
The chain slows down or stops when cutting. The engine runs fine and doesn not slow down. I checked the oil, cleared the oil vents to the chain, the brake is fine and is not causing the problem. The...
THE SAW IS RUNNING FINE . WHEN THE CHAIN STOPS AND THE ENGINE IS STILL RUNNING AT HI THROTTLE THE CLUTCH MAY BE WORN AND SLIPPING. PULL THE CHAIN AND BAR AND SEE IF THE CLUTCH HOUSING IS BLUEISH IN COLOR IF SO I WOULD REPLACE THE CLUTCH
Sep 17, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Hedge trimmer not cutting
Try getting the blades sharpened. Also have them checked to see if they are tight together, sort of like a pair of scissors. If the screws holding the blades together are sloppy the blades can't cut.
Jun 22, 2009 | Garden
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
