Question about Brother LS-2125 Mechanical Sewing Machine
The machine is sewing several stitches then skops a long line then several stitches ....
  • 4 Answers
SOURCE: machine skips stitches when sewing thru several layers of fabrics
Is your needle new? The needle needs to be replaced every 8 hours on a regular sewing machine, and the ULT benefits from even more frequent changes. Also try a bigger needle, if you're using a 75/11 move to a 90/14, make sure your needle matches what you're doing, you might not think those little needle tips differ much but they really do.
The manual also mentions if there is to much lint under the needle plate. Keep in mind all sewing machines need the bobbin area cleaned out every time you change the bobbin, but the ULT likes cleaning up down there about twice as often.
Posted on Nov 23, 2008
vash4me
  • 5 Answers
SOURCE: Machine sews zigzag although stitch is set at 0 for straight
It must be a design flaw- things don't always last like they are supposed to. I would personally check the physical reason it is not responding... knowing what it would take to make it stop moving- or whatis causing it to. *perhaps the switch isn't working to stop it- or the mechanism that controls it is worn down. If it was new- I'd return it- but there are only a few options at this point.
Posted on Jan 13, 2009
  • 37 Answers
SOURCE: Sewing hems on pants without stitch showing
you want to use a blind stitch. Refer to your manual and it should give you details on how to set the machine for that stitch.
Posted on Apr 16, 2009
  • 54 Answers
SOURCE: Sewing Machine is a Brother
the zigzag may be froze up. or the selector may be froze.
Posted on Aug 19, 2010
  • 1788 Answers
SOURCE: I sewed small zig zag stitches with no poblem but
I would call Brother, at 1-877-276-8437 and find out what they think is the problem, and have them advise you where to take it. In the meantime, make sure nothing is up in the shaft where you needle goes in, try to clean it out. That is really a strange problem. Good luck.
Posted on Oct 11, 2010
Skipped stitches
Skipped stitches could result from several different origins. First, easiest, and least expensive thing, try a brand new needle. However, if it is failing to pick up the bobbin thread all together, then it is probably out of time (search for sewing machine timing or take it for service).
Here are other suggestions for intermittent skipping:
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Basic Maintenance Tension Skipped Stitches
http://www.sewingreviews.org/what-to-do-when-your-machine-starts-skipping-stitches
Jan 03, 2017 | Sewing Machines
Homestyles sewing machine F08 702 H 01: Are they ALL caca, or just mine?
If it was purchased second-hand, very likely something is wrong with the machine or the owner didn't know how to use it. It is always best to test and have the owner show you how to use the machine before purchasing. From the information found online, this is a very economical level sewing machine--even new.
JMHO, but purchasing an old mechanical machine from a sewing machine shop for $60 would probably yield a more reliable machine. For most sewing, a straight stitch and zig-zag are the most frequently used stitches. So, if you are unable to purchase an upper-scale machine with multiple built-in design stitches for several hundred dollars, stick with a simple mechanical.
Jan 01, 2017 | Sewing Machines
How do I make a new buttonhole on my 1260? B
Hi Karen,
Sew two parallel lines of overlock stitches very close together. Then see overlock stitches accros the ends of the first lot of stitches to close them off. Finally, carefully cut the fabric between the first set of stitches. Try this out several times on some scrap fabric. You'll need to get the spacings sorted out.
Jul 19, 2015 | Sewing Machines
How do I get my sewing machine to sew with correct tension and straight stitches?
Over time, internal adjustments and servicing is required, at a sewing centers, service dept.
Take it in, have them look and repair, pay the nominal charge!
you will be glad you did!
Apr 16, 2015 | Sewing Machines
Make a rolled hem
If you want it done entirely by machine you will need a special attachment. You'd have to check the make and model of your machine to find out if there is an attachment available from the maker. If not, there are some companies that make general attachments, and they'll list what machines these will fit. Check online sewing supply houses for this kind of thing.
You can also make one by hand. Any decent sewing book would tell you how. Usually you sew a straight stitch along the hem, using quite small stitches. Trim hem to a quarter inch from the stitch line. Crease the fabric or press it along the stitch line to the inside. Anchor your hand thread, then take a short stitch right along the stitch line. Next catch one thread of the fabric a quarter inch above the stitch line. It's just a basic running stitch, back and forth. Every few stitches, gently snug up the thread, which will roll the hem over. The finer the fabric, the smaller the stitches you take where they'll show should be.
There are some images that will help, if you enter the following search terms in google, you will see several pictures. Type the words," Illustrations for how to make a rolled hem by hand ? " and you will get a load of ideas.
Oct 09, 2014 | Sewing Machines
It wont stitch tee/shirt material it misses stitchs
If machine misses stitches consistently, it can be several things.
Needle not installed correctly, not threaded correctly, Bobbin case not installed correctly, make sure the bobbin itself is inserted correctly and spinning in the correct direction.
Finally, machine may need service the timing is off. All actions of a sewing machine are carefully "timed" to form a stitch while sewing. Sewing things that were too heavy for the machine or you hit the bobbin case while sewing can knock the machine out of adjustment.
Let a professional do the maintenance on your machine. Some may opt to show you how to do more in depth maintenance yourself at home.
Cheers,
Feb 01, 2013 | Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Jun 26, 2010 | Kenmore 15212 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
11 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
