Question about Brother MFC 7420 All-In-One Laser Printer
No connection no printing, it worked this moring .i don;t have cd
  • Brother Master
  • 32,281 Answers
You candownload the Brother printer drivers from their support WEB site. Please clickon this link and select your model printer to download :-http://www.brother.com.au/ProductsSolutions.aspx
Posted on Mar 11, 2011
We have a basic manual for the above camera but it often refers us to the owners manual which we only have in CD form and my husband wanted a printed copy to refer to. Can we get one of these
You have the CD, but not a printed manual, right?
So why don't you get the manual in the CD printed?
If you don't have the manual, you can download it. You need to specify the brand and model of the camera.
Usually the manual in the CD is printer-ready.
Aug 24, 2011 | Cameras
How do u use use lightscribe
Use the CD/DVD label maker program your burner should come with (or some other one). Create the CD/DVD label however you want, just don't be too extravagant... it may not come out very nice. Put your lightscribe CD/DVD media label-side down (upside down) into the tray and print away. Then you wait, wait, wait, and wait some more. Afterwards, you'll probably want to actually put some data on that disc.
Jul 27, 2011 | HP dvd1170e DVD-RAM Burner
Hi, I have brought my dell laptop at work with vista operating system. It connects to internet networks wirelessly. I am trying to connect the work printer to my laptop but am not sure how to start. The...
hi,
you do not need a CD to connect to the printer, what you should do is gain access to the print server. this can be done by asking your network administrator. in a situation where you don't have one or the network is an open one, you have to connect to the printer network, open your ipv4 properties and select obtain an ip address automatically, do the same with the DNS server and you're good to go.
just so i'm thorough, after connecting to the print server / network, you can access your network ipv4 properties by right-clicking on the network icon located at the lower right corner of your taskbar, (the bar at the bottom of your screen) usually in form of two computer monitors. select network and sharing center after right-clicking. a list of wireless network should be available if there are more than one wireless networks in the area. select view status of the print server / network, click on properties, a pop-up box appears. be sure 'file and printer sharing for microsoft network' is checked, double-click "internet protocol v4 (ip/tcpv4)' select obtain an ip address automatically, select the same for the dns server below. click OK you're good to go.
note
once you are successfully connected to the print server, click on Devices and Printers from the start menu, select the printer and allow the drivers to be installed from the server. once that is done, you can right-click on the printer and select set as default. after this all you have to do is connect and print whenever you want to.
hope this helps
let me know if there's anything you don't understand or if this doesn't resolve it.
Jul 18, 2011 | HP LaserJet P4015 Printer
I don't know which button to press for it to print. I have no instructions manual
You do not have to use the printer buttons to get a print except power on button after connecting to mains supply & usb/parallel cable to PC. After installing the driver in your PC, it will show in print menu of respective application. Nowadays the manual in pdf format is available in the driver CD/DVD itself.
sonsunny
Jun 28, 2011 | Office Equipment & Supplies
Hi!,...on my cdj 1000 ,its basically got no power & not lighting up etc,...has been working fine & is not plug or plug fuse.Please help!!! Regards!
maybe the ic link protectors? on the bothom print? they don't look like fuses at all, but more like thiristors... if you read the tekst on the print you'll be able to find them ;-)
Jun 15, 2011 | Pioneer CDJ-1000MKII CD Player
How to install brother mfc 420cn
In order for your printer to work, you need a Software Installation CD (If you don't have it, you can found it on internet as a "driver" or "software"). For your model, click HERE , download this driver and then install it.
I hope I helped you!
May 15, 2011 | Brother MFC 420CN All-In-One InkJet...
I have an hp psc 1215 all in one printer which will not print documents from my pc, but can print using when i want to photocopy a document. it is shown as ready so what am i doing wrong? help please
Could be a driver, could be a usb port but to even test this theory try reinatalling the print driver and change the plug to another usb port if this still does not shore this up you have a bad pcm module inside that needs to be replaced.
thanks and please leave postive feedback for your free answer today.
Nov 17, 2009 | HP PSC 1215 All-In-One InkJet Printer
I cannot print
there will be lot of possibilities .just follow all these steps.
first you make sure your printer is working fine just remove the test print form going to printer and faxes option just right click on it and give test print if it is print that means your application have some problem from where you removing print out if test page is not coming then you need to reinstall the drive of printer.
kindly uninstall the printer driver and software restart the system and don’t connect the usb cable 1st install the driver cd and when it prompt you for connect the usb cable then connect it and follow the instruction. It will resolve your problem.
In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs. Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd
Nov 17, 2009 | Office Equipment & Supplies
Printer will not print
Normal 0 This doesn’t help fix all printers because each situation is different and in most cases we don’t have enough information to determine the fix. So hope this will provide some help.
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 29, 2008 | Lexmark X85 All-In-One InkJet Printer
Black will not print
Hi springfield, From what you describe I don?t think it has anything to do with your printer drivers. I would try the following: -Run a couple of nozzle cleaning jobs. -If no change I would suspect a defective cartridge and would try a brand new HP cartridge. If these don?t work I?ll need some more details such as do you refill cartridges, buy remanufactured cartridges or use new HP. Also is this still under manufacturer?s warranty? I don?t want to suggest anything that would void it. Let us know what happens and please don?t forget to rate the posting.
Jan 23, 2007 | HP LaserJet 3300mfp All-In-One Printer
Brother MFC 7420 All-In-One Laser Printer Logo
23 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
