Question about Toshiba win-98-me.exe
How to erase windows me? - Toshiba win-98-me.exe
    Sergeant:
    Champion:
  • 205 Answers
When you install a new version of windows it will automatically delete previous versions of windows. IE windows ME
Posted on Mar 11, 2011
How do I delete a recording off my Sony Sony - ICDBX140 - 4GB
  1. Slide the HOLD?POWER ON/OFF switch in the direction of "POWER ON/OFF" to turn on the IC recorder, or towards the center to release the IC recorder from the HOLD status. The stop mode window appears.
  2. Select the file you want to erase when the IC recorder is in the stop or playback mode.
  3. Erase a selected file. When the IC recorder is in the stop mode, press and hold ERASE.
    When the IC recorder is in the playback mode, press ERASE.
  4. Press ERASE. "ACCESS" appears in the display window and the selected file will be erased.
    When a file is erased, the remaining files will advance so that there will be no space between files.
Hint
  • To cancel erasing, press souni_stop.png(stop) in step 3.
  • To erase a part of a file, divide the file into two files first, and then proceed with steps 3 through 4.
Mar 10, 2015 | Sony Video Cameras
Tip
How to Erase a Burned CD
CD-RW stands for CD re-writeable. This type of disc can be written on or "burned" multiple times. However, in order to burn music or data onto a CD-RW that already has something on it, you must first erase the current contents of the disc. No special software is needed to do this, as you can do it with the Windows Media Player program, which already comes installed on all computers with the Windows operating system. Regular CD-R discs cannot be erased or reused--the discs must be labeled as CD-RW.
Instructions
Step 1.
Click on the "Start" menu button in the lower left-hand corner of the screen. Select "Windows Media Player" from the pop-up menu.
Step 2.
Select the "Library" tab in the main Windows Media Player screen.
Step 3.
Insert the CD-RW that you want to erase in the CD-ROM drive. Close the "AutoPlay" window if it appears.
Step 4.
Right-click the CD-ROM drive in the "Navigation" pane on the left side of Windows Media Player. Select "Erase disc" from the drop-down menu. This will automatically erase the contents of the disc.
on Jul 17, 2010 | Computers & Internet
How do i erase hard drive to recycle desktop?
Just remember, if you format a hard drive, someone will need to have a Windows disk to reinstall Windows on it again, to be able to use the computer. Here is a good link with super info about erasing a hard drive: How To Completely Erase Hard Drive
Sep 01, 2014 | Microsoft Windows XP Home Edition
Windows\system32\drivers\viamraid.sys missing
If you have a windows install disk, then download active kill disk.
You need to erase the hard drive the right way, you don\'t format from NTFS to NTFS to erase a HDD.
Here is a free eraser, but you need to burn it to a **** and boot to it so it runs in DOS.
http://how-to-erase-hard-drive.com/downloadfree.htm
You can also go to Western digital and use the tools for HDD to erase.
Once the HDD is erased, your clear CMOS, reset the setting in the BIOS such as boot order, you should be able to reinstall windows and install all the correct drivers.
Apr 14, 2013 | Microsoft Windows Vista Home Premium with...
Reformat unmountable flash drive on mac?
Instructions
    • 1
      Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    • 2
      Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
      • 3
        Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
      • 4
        Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
      • 5
        Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
      • 6
        Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    May 27, 2012 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    How do I erase the hard drive?
    Hi to erase the hard drive you will need a windows disc, on a dell you put the disc in the drive, reboot and press F12 to get a boot menu. boot from the CD/DVD drive and follow the install windows process and when you see the choices of drive space to install on select delete partition. You asked how to erase the drive it is now erased . to reinstall windows continue with the CDs instructions,exit if you just want to dispose of the PC with no personal info on it.
    I hope this answers your question
    Please click accept or thumbs up
    Thanks
    Roety
    Aug 10, 2010 | Dell Dimension 4600 PC Desktop
    External wont open on mac
    if you have used the hard drive on a windows pc some format types cannot be recognized by mac
    follow these steps to make it usable by mac and windows
    *THIS WILL DELETE ALL FILES ON THE EXTERNAL HARD DRIVE AND DOE NOT ALWAYS WORK
    Go to Finder -> Application -> Utilities
    Double click for Disk Utility
    Select the external Hard Disk you wish to format at the left column
    Click on the Erase tab
    At the “Volume Format” select “MS-DOS File System”
    If you confirm to format your hard disk for mac and windows, Click on “Erase” button.
    Pop up window will ask to verify the erase procedure. Click the erase button again in the window to start the erase process.
    Once the erase process finish, your external hard disk may be able to use in Mac and Windows.
    Mar 20, 2010 | Apple iBook G4 (Z0AZW13397068) PC Notebook
    How to delet all the contacts from iphone
    If you are using itunes for windows and have synced your contacts with Windows address books and your contact list is now filles with all of your contacts email addresses, here is a quick way to delete your address book at once.
    create 2 empty text files on your desktop and rename them to
    AddressBookimages.sqlitedb
    and
    AddressBook.sqlitedb
    copy/overwrite these empty files into " /var/root/Library/AddressBook" folder, using "Ibrickr"
    this will empty your contacts list, since all contacts are stored in those two files.
    * This wont take effect untill you restart your phone
    Jan 04, 2010 | Apple iPhone Smartphone
    Erasing music from my sandisk sansa express mp3 player
    Use windows media player or windows explorer - see your user's manual for details -avaialble on Samsung website
    Aug 22, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
    Erase Files dropped from windows real player
    I used Windows Media Player to erase the music data that I dropped using Real Player on DVM 5120.
    Jul 29, 2008 | RCA RP5010 Digital Voice Recorder
    Computers & Internet Logo
    50 people viewed this question
    Top Toshiba Computers & Internet Experts
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
