Question about Kenmore Elite Oasis ST 6807 Dryer
Sears kenmore elite oasis dryer 110 67032600 check lint screen flashes doesn t heat all other functions seem to work... timers, cycles, etc - it just doesn't heat. I did a major cleaning through all of the airpathways and checked to make sure there is 240vac at the dryer... all sat there are a couple of sensors indicated in the parts diagrams that seem to affect the temperature an operation of the heating element, but... there is also some sort of pair of blue thermistors that are connected to the electrodes by the lint screen. I don't want to randomly buy a bunch of parts...
  • 3 more comments
  • rebetsch Mar 11, 2011
    inside the lint screen assembly, there are two electrodes that have two blue discs connected to them (Thermistors?)... they are not on the parts diagrams... could these be bad?
    Also, If I replace the thermostats & limit switches, will that fix the check lint screen warning light that comes on when it's powered up? or is that related to the electrodes?
    If you were to rank which of those items were the most likely to fail, which order would you guess?
    to be honest with you, if the the light keeps flashing untill I hit start, but the dryer heats up, then I'll be happy!
    thanks for helping... the heater coil is literally broken... the sensors continuity checked sat... i'm about to put it all back together
    Guru:
  • 262 Answers
This video will show you the most likely of the componenets that are responsible for no heat issue.
This is not your model but the parts are located in the same location next to your heating element.
If this will not correct your issue just post the results of the testing of the components and I will show you what is next to test. But 90% of the time this is the issue.I would leave the thirmistors alone for now.
Click on the link http://www.youtube.com/watch?v=Wd1OOYegkmA
Here is the diagram for your dryer,Looks as if the parts to check are on the lower right hand side in the front.
Click on the link http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Dryer-Parts/Model-11067032600/0583/0151200/K0801017/00003?blt=06&prst=0&shdMod=11067032600
Here is a link for all of your parts drawings.click on the link http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Dryer-Parts/Model-11067032600/0583/0151200?pathTaken=&prst=0&shdMod=11067032600
Posted on Mar 11, 2011
  • Keith Drake
    Keith Drake Mar 11, 2011
    What I'm trying to do is correct the heating issue first,then the lint light.You should be able to take these parts to your part store and they should check them for you.If not but a cheap multi meter from lowes or home depot for around $10.00 If you need help after buying one I can walk you through it. This is the order in which I think the issues are in.
    1.) change out the high limit fuse...these go bad often....especially if the unit was full of lint.
    2.) change the heater element.
    3.) thermostats...these rarely go bad
  • Keith Drake
    That is great news.....you saved yourself around $100.00
  • 4,323 Answers
Hi
I believe the that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then check the dryer belt and idler pulley...Hope this helps...please post back for further assistance.
Daniel
  • Daniel Scott
    Daniel Scott Mar 12, 2011
    You said: Thanks for helping....so does that mean its solved for you....if yes then I believe you have rejected my solution....
Dryer turns on then stops in 5 seconds and flashes F40 code. shuts down
Check lint filter, check vent outlet at dryer, and continue on through vent checking for lint to the exit area of the vent. Keeping the vent lint free saves energy and reduces drying time.
Sep 06, 2015 | Kenmore Elite Oasis ST 7806 Dryer
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Check the vent on the back. This is indicating a air flow issue. If the vent is clear ohm the heater out check it for continuity.
You can watch a video that explains how to complete this repair on your sears Kenmore Elite clothes dryer at the link below.
Sear Kenmore Dryer Video
Mar 11, 2011 | Kenmore Elite Oasis ST 6807 Dryer
We have a kenmore elite oasis dryer.one year old.just bought from some people only had it for two days.it was in the middle of a cycle when it suddenly shut off with the code af appearing where the timer...
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore Elite Oasis ST 6807 Dryer
Kenmore Elite Oasis 110.67087600 Dryer will not power up. No power at all. Prior to this it had a PF flashing. House power checked good.
If no-go.. the timer is failed due to a power spike and must be replaced.
Apr 26, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Check lint screen come on
Check the tubing the lint goes through (exhaust). This may be stopped up or clogged. There is a build up here of heat or something that is preventing proper air flow.
Dec 27, 2008 | Kenmore 659 Electric Dryer
Kenmore Dryer displaying erroneous letters
AF is restricted airflow clean lint filter and check your vent hose for kinks or obstuctions
Dec 02, 2008 | Kenmore 67082 Electric Dryer
Kenmore Elite Oasis ST 6807 Dryer Logo
497 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
